2fps in Montage after services reset
marvinl2010
Post by marvinl2010 »
Hello, I'm using 1.36.24, and I have some cameras connected and running 15 fps in Montage, if I restart both the zoneminder and the httpd services, the fps will drop to 2 until I refresh the browser again manually.
Is there a setting related to this issue?
I know I should manually refresh it after a server side reset, but I just got too lazy and thinking if it could automatically fix itself in such a situation.
Re: 2fps in Montage after services reset
In 1.36 if zms has a problem sending fast enough, it reduces it's target fps. There is no code to make it go back up though. I have rewritten a lot of this in 1.37.
marvinl2010
Thank you for the update!
