Page 1 of 1
High CPU load
Posted: Wed Oct 05, 2022 5:25 am
by yeyexen
hi!
Mu CPU Intel Core i5-4440 @3.10GHz
ZM v1.36.26
6 IP CAM.
CAM settings (CTV-IPD2028-FLE)
- cam
- 2022-10-05 08_12_29-CCTV - Monitor - cam_perimetr_1 – Brave.png (25.5 KiB) Viewed 398 times
- cam2
- 2022-10-05 08_15_05-CCTV - Monitor - cam_perimetr_1 – Brave.png (15.79 KiB) Viewed 398 times
CPU LOAD
- CPU load
- 2022-10-05 08_18_45-mRemoteNG - mremote.xml - SRV4.png (11.62 KiB) Viewed 398 times
This is fine? What's wrong with the setting? There are 4 more of the same cameras - CPU load 100%
Help me please!
Re: High CPU load
Posted: Wed Oct 05, 2022 5:26 am
by yeyexen
STORAGE SETTINS
- 2022-10-05 08_23_28-CCTV - Monitor - cam_perimetr_1 – Brave.png (9.64 KiB) Viewed 396 times
Re: High CPU load
Posted: Wed Oct 05, 2022 11:25 am
by iconnor
Turn off storing jpegs. That takes a lot of cpu on a high res stream.
Re: High CPU load
Posted: Wed Oct 05, 2022 1:01 pm
by yeyexen
then video streaming doesn't work
no solution to the problem?
- 2022-10-05 15_59_02-CCTV - Montage Review – Brave.png (19.84 KiB) Viewed 365 times
Re: High CPU load
Posted: Wed Oct 05, 2022 1:40 pm
by iconnor
It should still work. Check your logs.
Re: High CPU load
Posted: Fri Oct 07, 2022 5:25 am
by yeyexen
Hmmm...turned on and off Save JPEGs. Everything is fine.
what to look for?
- zm8.png (44.08 KiB) Viewed 317 times
