High CPU load
yeyexen
High CPU load
Post by yeyexen »
hi!
Mu CPU Intel Core i5-4440 @3.10GHz
ZM v1.36.26
6 IP CAM.
CAM settings (CTV-IPD2028-FLE)
cam
cam
2022-10-05 08_12_29-CCTV - Monitor - cam_perimetr_1 – Brave.png (25.5 KiB) Viewed 364 times
cam2
cam2
2022-10-05 08_15_05-CCTV - Monitor - cam_perimetr_1 – Brave.png (15.79 KiB) Viewed 364 times
CPU LOAD
CPU load
CPU load
2022-10-05 08_18_45-mRemoteNG - mremote.xml - SRV4.png (11.62 KiB) Viewed 364 times
:?: This is fine? What's wrong with the setting? There are 4 more of the same cameras - CPU load 100% :( Help me please!
yeyexen
Re: High CPU load
Post by yeyexen »
STORAGE SETTINS
2022-10-05 08_23_28-CCTV - Monitor - cam_perimetr_1 – Brave.png (9.64 KiB) Viewed 362 times
Re: High CPU load
Turn off storing jpegs. That takes a lot of cpu on a high res stream.
yeyexen
Re: High CPU load
Post by yeyexen »
then video streaming doesn't work :(
no solution to the problem?
2022-10-05 15_59_02-CCTV - Montage Review – Brave.png (19.84 KiB) Viewed 331 times
Re: High CPU load
It should still work. Check your logs.
yeyexen
Re: High CPU load
Post by yeyexen »
Hmmm...turned on and off Save JPEGs. Everything is fine.
what to look for?
