Console not showing events
Fedora FC36 on laptop - new install - had 2 problems: 1) link missing for cache in /usr/share/zoneminder/www and 2) link missing for cgi-bin in /usr/share/zoneminder. Up and running, camera shows however on the Console page events, which are recording, show as [ null null null null null ] and Zone, which is working shows as [ 0 ]. Google hasn't been any help. Hope someone here is better.
Re: Console not showing events
Missed adding it's the camera events showing null null null... but the the Totals for all cams (1) show "0"
Looked at logs?
Sounds like maybe ZM can't write to database. There should always be "1" zone...
I too am experiencing this on a fresh install of Lubuntu 22.04 using ZM1.37, and Mariadb.
Had a previous install, but on slow HDD and did a fresh install on an SSD.
Followed the instructs here:
https://bkjaya.wordpress.com/2022/05/24 ... ntu-focal/
Added my Cameras all Wireless 1080P cams, except for one older 640X480 unit.
It was working, but something changed, and it made the MariaDB unable to start.
I fixed that by removing the entry for TZ from a config file.
I do have events in the file system, and I can see the events in chronological order using the ZMNinja app on my Android phone.
I can go to Audit Events Report in ZM Web GUI, and there are events, and I can click and play them via browser either on the ZM Server, or on my Windows PC, locally or remotely (Have DDNS and port forwarding).
I know that this is most likely one line in a configuration file.
Wondering if best to just redo the ZM install, or find the silver bullet?
Screenshot of my ZM Audit Events Page and then my Console in Chrome on Windows 10.
Update, I resolved the 0 zone issue by running a mysql command.
- ZM Events 10-3-2022.JPG (84.59 KiB) Viewed 873 times
- zm console 10-2-2022.JPG (107.96 KiB) Viewed 874 times
Do you get anything in the log when you click and it spins?
BTW, you can post screenshots here using the Attachments tab below...
SOLVED
ZM was installed via: dnf install zoneminder zoneminder-common zoneminder-httpd
for some reason db/triggers.sql didn't get run
Not sure if anything else (sql) didn't run - but Console page is now listing Events.
