Just Updated to 1.37.22 - nothing working -
homebrewdude
Post by homebrewdude »
Here is a snip from my log.
9/19/22, 9:41:22 AM EDT zmdc 97860 ERR 'zmc -m 3' exited abnormally, exit status 255 zmdc.pl -
9/19/22, 9:41:22 AM EDT zmdc 97860 ERR 'zmc -m 5' exited abnormally, exit status 255 zmdc.pl -
9/19/22, 9:41:22 AM EDT zmdc 97860 ERR 'zmc -m 2' exited abnormally, exit status 255 zmdc.pl -
9/19/22, 9:41:22 AM EDT zmc_m6 103828 ERR No monitors found zmc.cpp 215
9/19/22, 9:41:22 AM EDT zmc_m1 103829 ERR No monitors found zmc.cpp 215
9/19/22, 9:41:22 AM EDT zmc_m1 103829 ERR Can't use query result: Unknown column 'Janus_RTSP_User' in 'field list' zm_monitor.cpp 793
9/19/22, 9:41:22 AM EDT zmc_m6 103828 ERR Can't use query result: Unknown column 'Janus_RTSP_User' in 'field list' zm_monitor.cpp 793
9/19/22, 9:41:22 AM EDT zmc_m1 103829 ERR Can't run query: Unknown column 'Janus_RTSP_User' in 'field list' zm_db.cpp 129
9/19/22, 9:41:22 AM EDT zmc_m6 103828 ERR Can't run query: Unknown column 'Janus_RTSP_User' in 'field list' zm_db.cpp 129
9/19/22, 9:41:22 AM EDT zmc_m5 103827 ERR No monitors found zmc.cpp 215
Re: Just Updated to 1.37.22 - nothing working -
looks like the db update script didn't happen.
sudo zmupdate.pl
if that doesn't fix it...
mysql -u zmuser -p zm < /usr/share/zoneminder/db/zm_update-1.37.22.sql
nrbell
Post by nrbell »
I think that the missing update is actually in /usr/share/zoneminder/db/zm_update-1.37.23.sql.
homebrewdude
This did not work
This might have worked, the monitors turned on, no more errors
mysql -u zmuser -p zm < /usr/share/zoneminder/db/zm_update-1.37.23.sql
