Tp-Link Tapo C310 'zmc -m 2' exited abnormally, exit status 255
Findeton
Post by Findeton »
Hi, I have a Raspberry Pi 400 with Raspberry OS (debian 11/bullseye) and Zoneminder 1.36.25. I also have a TAPO TP-Link C310.
When I open this url on VLC, it works:
rtsp://user:password@192.168.1.9:554/stream1
But when I add the camera to ZoneMinder, it says it's not capturing, and on the logs I get the ominous:
This is the log screen:
I've been unable to configure it to connect to the camera. This is the current configuration (for the screenshots I've replaced the actual user/pass with fake ones):
I can see in the docs that ZoneMinder should support the camera, so why is it not working? how can I solve it? When I load the rtsp url on VLC it does work...
Please I'd greatly appreciate some help here!
Re: Tp-Link Tapo C310 'zmc -m 2' exited abnormally, exit status 255
Might it want UDP?
Findeton
Post by Findeton »
dougmccrary wrote: Sat Sep 17, 2022 1:12 am Might it want UDP?
I tried UDP and the logs show the same error:
I also tried UDP multicast and I get:
Unable to open input rtsp://192.168.1.9:554/stream1 due to: Server returned 400 Bad Request
Failed to prime capture of initial monitor
I also tried HTTP Tunnel and I get:
Unable to open input rtsp://192.168.1.9:554/stream1 due to: Input/output error
Got any special characters in the uname or pass?
Just in case, I've noticed some cams are case sensitive to the uname.
I don't have that camera so that's all I got. Good luck with it.
tinymouse
Post by tinymouse »
I have one of these cams and it's working just fine with ZoneMinder 1.36.25 and now .26 with Ubuntu 20.04. The only difference I see here is I'm not saving the audio on the storage tab.
rtsp://user:pass@192.168.1.198:554/stream1
TCP; 32bit color 1920x1080 (mine also works with VLC)
pat2
Post by pat2 »
I have 5 Tapo C200 cams working fine with 1.36.26.
The syntax you used is correct.
Have you tried lower resolution?
ZM 1.36.34 - 14 cameras on Orange Pi 5 (arm64) - Ubuntu Jammy 22.04
gryzor
Post by gryzor »
Greetings,
I had the very same problem with another rtsp camera. After upgrading to 1.36.26 (through debian stable backports), no matter which parameters I tried, "zmc -m 3" kept returning 255 just after it started.
I believe it is a problem specific to post-upgrade.
I spent a lot of time, and once I started running tcpdump to capture network datagrams, I had the surprise to discover that zmc never sent any network query to the camera.
Then I ran "zmc -m 3" by hand, to see its output.
The output was complaining about some "ZM_SOMETHING_OPT_AUTH" and suggested I run "zmupdate.pl -f", which I did (as root, still). After that, adding a camera started sending network probes and I have been able to setup my camera.
Also, after that, I deleted my camera from the console and created a new one instead (not sure that is needed).
@developers : I believe it is very much needed that zmc's STDOUT/STDERR be displayed somewhere on the console to report errors. This would have saved me a lot of time ; and maybe some users are keeping stuck forever because of such effects.
gryzor
