pepex7 wrote: ↑Thu Apr 27, 2023 10:30 pm
geraldbrandt wrote: ↑Mon Aug 22, 2022 4:04 pm
I run seven cameras and do all of my motion detection at the lowest resolution of the camera (640x360 ish). I then have a linked monitor at full res (usually 4k) that saves with camera passthrough. I'm running in an LXC container under Proxmox with 4CPUs (i7-3700). My load average is .75 and 7% cpu usage.
what storage configuration are you using?
can you guide me? I'm trying to implement in proxmox
So, I've changed things a bit. Linked monitors suck... they fail all the time, record differently than the detection screen. They're just a bad idea.
I still have seven cameras. I capture the hi resolution stream, but tell Zoneminder the capture resolution is 640x360. That means all my motion detection happens on a 640x360 image. When motion is detected, I save RTSP passthrough to disk, which is the highest resolution the camera puts out.
Watching a live stream shows the 640x360 images, so it's not great. I almost never do that, though. Montage view looks great, since all the mages are smaller anyway. I do that a lot.
The end result on an i5-12500 in a VM is .8 load and 10-15% CPU. The system is stable and fast.
My VM storage is to an NFS server over 1Gbe (Synology box). I have no issues.
Any other questions?
Gerald
This camera's RTSP stream is 1920x1080
- Screenshot_2023-04-28_07-47-02.png (55.94 KiB) Viewed 1779 times
