Hello, everyone,
I integrated an IP cam into ZoneMinder via RTSP and defined a zone to detect movement. This also works perfectly. Unfortunately, however, most of the recordings are too short for my needs.
How or where can you set that if a movement is detected, the recording should basically e.g. continue walking for 20 seconds.
Attached are some screenshots of the settings.
Thank you for your support.
Define the duration of the recording for Modect Capturing
- Screenshot 2022-08-15 at 08.13.39.png (68.92 KiB) Viewed 303 times
- Screenshot 2022-08-15 at 08.13.23.png (208.52 KiB) Viewed 303 times
- Screenshot 2022-08-15 at 08.12.43.png (574.47 KiB) Viewed 303 times
Re: 50 / 5.000 Übersetzungsergebnisse Define the duration of the recording for Modect Capturing
It's all here - https://zoneminder.readthedocs.io/en/st ... nitor.html
It's under Buffers, Post Event Image Count
