Define the duration of the recording for Modect Capturing
Posted: Mon Aug 15, 2022 6:16 am
Hello, everyone,
I integrated an IP cam into ZoneMinder via RTSP and defined a zone to detect movement. This also works perfectly. Unfortunately, however, most of the recordings are too short for my needs.
How or where can you set that if a movement is detected, the recording should basically e.g. continue walking for 20 seconds.
Attached are some screenshots of the settings.
Thank you for your support.
