Linux Mint Upgrade to 21 wants to downgrade zoneminder to 1.32.3
homebrewdude
Post by homebrewdude »
Anyone run and update Linux Mint recently?
Anyway around downgrading Zoneminder from 1.37.20 to 1.32.3
Re: Linux Mint Upgrade to 21 wants to downgrade zoneminder to 1.32.3
Make sure you still have the 1.37 PPA since the upgrade.
homebrewdude
It won't even install unless I downgrade it.
Seems odd
Run this
apt-cache madison zoneminder
Post output.
homebrewdude
~$ apt-cache madison zoneminder
zoneminder | 1.37.22~20220914133132-focal | http://ppa.launchpad.net/iconnor/zonemi ... ter/ubuntu focal/main amd64 Packages
zoneminder | 1.32.3-2ubuntu2 | http://mirror.cc.vt.edu/pub2/ubuntu focal/universe amd64 Packages
It should be installing the latest version available, so that’s a bit odd.
Might be worth working through this to try to get it to install 1.37. https://itsfoss.com/apt-install-specific-version/
Of course you can grab a .deb file, install that and see if it straightens out.
saveconi
Post by saveconi »
I have the very same problem.
Upgrading from 20.3 to 21 the mint upgrade system doesn't let you to continue unless you downgrade zoneminder.
After downgrading it..... it stops working! (Apache seems to be totally screwed up! Missing web page!).
