Re: Unable to view configure stream
Posted: Tue Aug 09, 2022 2:23 am
by NugentS
Stopping zmwatch seemed to have no effect
Log Files just show
Date/Time,Component,Server,PID,Level,Message,File,Line
"2022-08-09 03:09:22",zmc_m2,,32762,ERR,"Failed to prime capture of initial monitor",zmc.cpp,258
"2022-08-09 03:09:22",zmc_m2,,32762,ERR,"Unable to open input rtsp://192.168.38.163/bcs/channel0_sub.bcs?channel=0&stream=1&user=admin&password=XXXXXXXXXXXXX due to: Immediate exit requested",zm_ffmpeg_camera.cpp,321
If thats any help - its just cycles round and around (this is after stopping zmwatch
I have no choice about the version - using TrueNAS Scale and the version available through Truecharts. Even they say its experimental.
I have an assorted selection of cameras - they all work through Synology apart from one that just sometimes works and sometimes vanishes off the network for a day or so, then comes back again (not this camera). I even have a new RLC-842A still boxed that I keep meaning to do something with.
I restarted the container and looked at the logs and got....(if its any use)
"2022-08-09 03:21:20",web_php,,30234,DBG,"View: request Request: log Action: User: admin",/usr/share/zoneminder/www/index.php,233
"2022-08-09 03:21:20",web_php,,30234,DBG,"Setting cookie parameters to Array( [lifetime] => 3600 [path] => / [domain] => [secure] => [httponly] => 1 [samesite] => Strict)",/usr/share/zoneminder/www/includes/session.php,28
"2022-08-09 03:21:18",zmdc,,30073,INF,"'zmc -m 2' crashed, signal 8",zmdc.pl,'-
"2022-08-09 03:21:18",zmdc,,30073,WAR,"'zmc -m 2' has not stopped at 22/08/09 03:21:18 after 10 seconds. Sending KILL to pid 30283",zmdc.pl,'-
"2022-08-09 03:21:18",web_php,,30234,DBG,"View: request Request: log Action: User: admin",/usr/share/zoneminder/www/index.php,233
"2022-08-09 03:21:18",web_php,,30234,DBG,"Setting cookie parameters to Array( [lifetime] => 3600 [path] => / [domain] => [secure] => [httponly] => 1 [samesite] => Strict)",/usr/share/zoneminder/www/includes/session.php,28
"2022-08-09 03:21:15",web_php,,30234,DBG,"View: request Request: log Action: User: admin",/usr/share/zoneminder/www/index.php,233
"2022-08-09 03:21:15",web_php,,30234,DBG,"Setting cookie parameters to Array( [lifetime] => 3600 [path] => / [domain] => [secure] => [httponly] => 1 [samesite] => Strict)",/usr/share/zoneminder/www/includes/session.php,28
"2022-08-09 03:21:10",web_php,,30234,DBG,"View: request Request: log Action: User: admin",/usr/share/zoneminder/www/index.php,233
"2022-08-09 03:21:10",web_php,,30234,DBG,"Setting cookie parameters to Array( [lifetime] => 3600 [path] => / [domain] => [secure] => [httponly] => 1 [samesite] => Strict)",/usr/share/zoneminder/www/includes/session.php,28
"2022-08-09 03:21:09",zmc_m2,,30283,DB2,"Starting connection attempt to 192.168.38.163 port 554",zm_ffmpeg.cpp,69
"2022-08-09 03:21:09",zmc_m2,,30283,DB3,"Address 192.168.38.163 port 554",zm_ffmpeg.cpp,69
"2022-08-09 03:21:09",zmc_m2,,30283,DB3,"Interleaved list of addresses:",zm_ffmpeg.cpp,69
"2022-08-09 03:21:09",zmc_m2,,30283,DB3,"Original list of addresses:",zm_ffmpeg.cpp,69
"2022-08-09 03:21:09",zmc_m2,,30283,DB3,"No default whitelist set",zm_ffmpeg.cpp,69
"2022-08-09 03:21:09",zmc_m2,,30283,DB8,"Probing rtsp score:100 size:0",zm_ffmpeg.cpp,69
"2022-08-09 03:21:09",zmc_m2,,30283,DB1,"Calling avformat_open_input for rtsp://192.168.38.163/bcs/channel0_sub.bcs?channel=0&stream=1&user=admin&password=XXXXXXXXX",zm_ffmpeg_camera.cpp,307
"2022-08-09 03:21:09",zmc_m2,,30283,DB1,"Priming capture from rtsp://192.168.38.163/bcs/channel0_sub.bcs?channel=0&stream=1&user=admin&password=XXXXXXXXX",zm_ffmpeg_camera.cpp,183
"2022-08-09 03:21:09",zmc_m2,,30283,DB3,"Success connecting",zm_monitor.cpp,1067
"2022-08-09 03:21:09",zmc_m2,,30283,DB3,"Allocated 3 3 image buffers",zm_monitor.cpp,1014
"2022-08-09 03:21:09",zmc_m2,,30283,DB3,"Aligning shared memory images to the next 64 byte boundary",zm_monitor.cpp,1004
"2022-08-09 03:21:09",zmc_m2,,30283,DB1,"Mapped file /dev/shm/zm.mmap.2 (3691960 bytes) to unlocked memory",zm_monitor.cpp,971
"2022-08-09 03:21:09",zmc_m2,,30283,DB1,"Unable to map file /dev/shm/zm.mmap.2 (3691960 bytes) to locked memory, trying unlocked",zm_monitor.cpp,968
"2022-08-09 03:21:09",zmc_m2,,30283,DB3,"MMap file size is 0",zm_monitor.cpp,963
"2022-08-09 03:21:09",zmc_m2,,30283,DB3,"Success opening mmap file at (/dev/shm/zm.mmap.2)",zm_monitor.cpp,930
"2022-08-09 03:21:09",zmc_m2,,30283,DB3,"Connecting to monitor. Purpose is 1",zm_monitor.cpp,917
"2022-08-09 03:21:09",zmc_m2,,30283,INF,"Starting Capture version 1.36.12",zmc.cpp,220
"2022-08-09 03:21:09",zmc_m2,,30283,DB2,"1 monitors loaded",zmc.cpp,217
"2022-08-09 03:21:09",zmc_m2,,30283,DB1,"Loaded monitor 2(Front of House (Sub)), 1 zones",zm_monitor.cpp,694
"2022-08-09 03:21:09",zmc_m2,,30283,DB1,"Reloading zones for monitor Front of House (Sub) have 1",zm_monitor.cpp,2330
"2022-08-09 03:21:09",zmc_m2,,30283,DB3,"Successfully parsed polygon string 0,479",zm_zone.cpp,777
"2022-08-09 03:21:09",zmc_m2,,30283,DB3,"Got coordinate 0,479 from polygon string",zm_zone.cpp,765
"2022-08-09 03:21:09",zmc_m2,,30283,DB3,"Got coordinate 639,479 from polygon string",zm_zone.cpp,765
"2022-08-09 03:21:09",zmc_m2,,30283,DB3,"Got coordinate 639,0 from polygon string",zm_zone.cpp,765
"2022-08-09 03:21:09",zmc_m2,,30283,DB3,"Got coordinate 0,0 from polygon string",zm_zone.cpp,765
"2022-08-09 03:21:09",zmc_m2,,30283,DB5,"Parsing polygon 0,0 639,0 639,479 0,479",zm_zone.cpp,870
"2022-08-09 03:21:09",zmc_m2,,30283,DB1,"Got 1 zones for monitor Front of House (Sub)",zm_zone.cpp,839
"2022-08-09 03:21:09",zmc_m2,,30283,DB3,"Reloading zones for monitor Front of House (Sub) have 0",zm_monitor.cpp,2328
"2022-08-09 03:21:09",zmc_m2,,30283,INF,"Enabling ffmpeg logs, as LOG_DEBUG+LOG_FFMPEG are enabled in options",zm_ffmpeg.cpp,84
"2022-08-09 03:21:09",zmc_m2,,30283,DB2,"New camera id: 2 width: 640 line size: 2560 height: 480 colours: 4 subpixelorder: 8 capture: 1",zm_camera.cpp,68
"2022-08-09 03:21:09",zmc_m2,,30283,DB1,"mem.size(8) SharedData=760 TriggerData=560 VideoStoreData=4128 timestamps=48 images=3x1228800 = 3686400 total=3691960",zm_monitor.cpp,658
"2022-08-09 03:21:09",zmc_m2,,30283,DB1,"Setting max_video_packet_count to 0",zm_packetqueue.cpp,654
"2022-08-09 03:21:09",zmc_m2,,30283,DB1,"Setting pre_event_video_packet_count to 5",zm_packetqueue.cpp,660
"2022-08-09 03:21:09",zmc_m2,,30283,DB3,"Decoding enabled: 1 function 5 Mocord savejpegs 3 videowriter 2",zm_monitor.cpp,570
"2022-08-09 03:21:09",zmc_m2,,30283,DB1,"Reloading linked monitors for monitor Front of House (Sub), '(null)'",zm_monitor.cpp,2336
"2022-08-09 03:21:09",zmc_m2,,30283,DB1,"Have camera type File",zm_monitor.cpp,493
"2022-08-09 03:21:09",zmc_m2,,30283,DB1,"No id passed to Storage constructor. Using default path /var/cache/zoneminder/events instead",zm_storage.cpp,91
"2022-08-09 03:21:09",zmc_m2,,30283,DB4,"Image buffer copy: Using standard memcpy",zm_image.cpp,566
"2022-08-09 03:21:09",zmc_m2,,30283,DB4,"Deinterlace: Using standard functions",zm_image.cpp,553
