Cant adjust zones in 1.36.21
ZoneMindingFinding
Post by ZoneMindingFinding »
Just upgraded to 1.36.21. Now when I try to change any zones... the page where you do so with the green dot handles keeps rapidly refreshing itself and doesn't let any changes take place due to the refreshing. Tested on Firefox, Chrome, and Edge. Is this a bug in 1.36.21 or something specific to my computer?
Re: Cant adjust zones in 1.36.21
Works for me.
I think I might have seen this and have a fix queued in proposed... memory is foggy though.
urbnsr
Post by urbnsr »
I am running 1.36.24 and cannot adjust nor add new zones. No points to grab with a mouse on zone 1, and clicking on SAVE at the bottom of the screen doesn't seem to do anything although the mouse pointer changes to a pointing finger/hand when hovering over it.
I might be aware of the issue. I'll take look tomorrow.
urbnsr
Post by urbnsr »
Thanks.
I think I may have caused my own problems. I was running your master 1.37 version and have recently downgraded back to 1.36.24. I wonder if that is causing this? Although I don't go into the Zone section often, I can't think of anything else that has changed.
