Page 1 of 1
How to save the images in a the Hdd external?
Posted: Tue Nov 23, 2021 5:10 am
by dougmccrary
Just point to it in options->Storage
Re: How to save the images in a the Hdd external?
Posted: Tue Nov 23, 2021 10:40 am
by burger
How did you end up in 1.30? You should be using 1.34 or 1.36.
Guide is here:
https://wiki.zoneminder.com/Using_a_ded ... Hard_Drive
Posted: Tue Nov 23, 2021 11:06 pm
by kitkat
I've always found it easier to change the default storage area and deal with everything in just one place rather than add another one.
There's a guide to using a dedicated partition in this way here:
https://zoneminder.readthedocs.io/en/la ... work-share
Another easy option is to create the ZM events/* directory structure on a new disk and then mount it directly (or bind mount it) over the existing one. There's nothing to change or edit that way, apart from adding the mount point to /etc/fstab.
Posted: Wed Nov 24, 2021 1:24 am
by dougmccrary
kitkat
+1
