Broken v1.37.18 - ONVIF_Alarm_Txt
lyallp
Post by lyallp »
Language translation issue I suspect.
I found this text in two places.
/usr/share/zoneminder/www/lang/es_la.php:    'ONVIF_Alarm_Txt'      => 'Texto Alarma ONVIF', //added 18/07/2022
/usr/share/zoneminder/www/skins/classic/views/monitor.php:              <td class="text-right pr-3"><?php echo translate('ONVIF_Alarm_Txt') ?></td>
Results in log messages of
Jul 21 09:35:13 Lyalls-PC zmc_dvideo0[17314]: ERR [zmc_dvideo0] [Can't run query: Unknown column 'ONVIF_Alarm_Txt' in 'field list']
Jul 21 09:35:13 Lyalls-PC zmc_dvideo0[17314]: ERR [zmc_dvideo0] [Can't load local monitors: Unknown column 'ONVIF_Alarm_Txt' in 'field list']
Jul 21 09:35:13 Lyalls-PC zmc_dvideo0[17314]: ERR [zmc_dvideo0] [No monitors found]
Jul 21 09:35:13 Lyalls-PC zmdc[17224]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
...Lyall
Aen5quai
Re: Broken v1.37.18 - ONVIF_Alarm_Txt
Post by Aen5quai »
I've this issue too
Centos7
zoneminder-httpd-1.37.18-1.70.20220720gitg95530a4f7.el7.x86_64
zoneminder-common-1.37.18-1.70.20220720gitg95530a4f7.el7.x86_64
zoneminder-1.37.18-1.70.20220720gitg95530a4f7.el7.x86_64
[root@www db]# ls -al zm_update-1.37.1*
-rw-r--r--. 1 root root  449 май 18 20:03 zm_update-1.37.10.sql
-rw-r--r--. 1 root root  509 май 18 20:03 zm_update-1.37.11.sql
-rw-r--r--. 1 root root 2689 май 18 20:03 zm_update-1.37.12.sql
-rw-r--r--. 1 root root  561 май 18 20:03 zm_update-1.37.13.sql
-rw-r--r--. 1 root root   96 май 18 20:03 zm_update-1.37.14.sql
-rw-r--r--. 1 root root  457 май 18 20:03 zm_update-1.37.15.sql
-rw-r--r--. 1 root root  254 май 18 20:03 zm_update-1.37.16.sql
-rw-r--r--. 1 root root  418 июн 18 14:35 zm_update-1.37.17.sql
-rw-r--r--. 1 root root  482 июл 13 00:34 zm_update-1.37.18.sql
-rw-r--r--. 1 root root   58 май 18 20:03 zm_update-1.37.1.sql
[root@www db]# pwd
/usr/share/zoneminder/db
[root@www db]# grep -i ONVIF_Alarm_Txt *
[root@www db]#
Run
monitors_dbupdate.sql
Aen5quai
Post by Aen5quai »
whereis monitors_dbupdate.sql; echo $?
monitors_dbupdate:0
zmupdate.pl
Database already at version 1.37.18, update skipped.
Whereis monitors_dbupdate.sql located?
lyallp
Post by lyallp »
sort of expected zmupdate.pl to do it's job.
My Gentoo ebuild has not included this monitors_dbupdate.sql, which does not appear to conform to previous update naming standards, such as 'zm_update-1.37.9.sql'
I did, however, find this rogue sql in the git repository, arrived about 17 hours prior to this post.
ALTER TABLE zm.Monitors ADD Onvif_Alarm_Txt varchar(30) DEFAULT 'MotionAlarm' NULL;
...Lyall
In the usual DB folder.
Aen5quai
Post by Aen5quai »
Yes, that works. Thank you.
wget https://raw.githubusercontent.com/ZoneMinder/zoneminder/master/db/monitors_dbupdate.sql
mysql -p zm < monitors_dbupdate.sql
systemctl restart zoneminder
You're welcome. It's part of the joys of running the development version.
I'd suggest cloning the git repo and having a rummage through when the DB doesn't behave.
lyallp
Post by lyallp »
My points are
1. DB changes should give a point version bump
2. DB Changes should be in the same form as previous DB changes
3. DB Changes should apply automatically with zmupdate.pl
Failure on any of these points will potentially lead to a broken release distribution, down the track, as the DB update is 'forgotten'
...Lyall
Development version.
lyallp
Post by lyallp »
Which is the precursor to a release version.
...Lyall
No, it’s not at all. This is a different branch.
You’d be running the ‘proposed’ version if you want the one that’s just about to be the next release.
lyallp
Post by lyallp »
Ok, it's just that all previous updates of Zoneminder dealt with database updates in the manner described earlier.
If this is the way it is, then it's the way it is.
...Lyall
Some fixes pushed. 1.37.19 should handle the update correctly. Of course I probably missed something or screwed something up. We will find out shortly.
lyallp
Post by lyallp »
Broke it again.
Was
ONVIF_Alarm_Txt
now it's
 ONVIF_Alarm_Text
...Lyall
