Can't create USB local camera monitor on Zoneminder master 1.37.18~20220714175957-bionic [ Solved ]
bkjaya1952
Post by bkjaya1952 »
I have tested the following Zoneminder master latest releases with Ubuntu focal & Ubuntu bionic
1. 1.37.18~20220714175957-focal with MSMTP & php7.4 , MariaDB Server 10.3.34 ------USB camera monitor can be created without any problem and working nicely.
2. 1.37.18~20220714175957-bionic with MSMTP & .php7.2 , Mysql5.7 -----USB camera monitor can't be created.
No errors were found in the logs. The buttons below the General tab are not functioning in the monitor panel
ZM panel is given below
Re: Can't create USB local camera monitor on Zoneminder master 1.37.18~20220714175957-bionic
Please check JavaScript console and view page source for breakage
bkjaya1952
iconnor wrote: Sat Jul 16, 2022 4:29 pm Please check JavaScript console and view page source for breakage
Thank you Sir !
bkjaya1952
Re: Can't create USB local camera monitor on Zoneminder master 1.37.18~20220714175957-bionic [ Solved ]
I have tested Zoneminder-master latest 1.37.19~20220810103212-bionic latest release and found that the USB monitor can be created.
Dear Sir
Thank you very much for resolving the issue !
Screenshot from 2022-08-11 19-37-47.png (326.22 KiB) Viewed 2767 times
