hoping one of you can be kind enough to sort me out.
I've finally got round to looking at Pushover working with ZM and have my Pushover key and token etc.
I can send notifications from the Pushover app on my PC to my IOS phone ok and I think I have ZM set up correctly by following the guides and tips in this forum.
But it doesn't seem to work for me - I tried re-installing Ninja as I thought it might be a token problem on my phone but was surprised it still picked up on all my credentials and still didn't work.
I've tried with my credentials in the secrets.ini file and also directly in the pushoverapi.py just in case they weren't being picked up.
In the zmevent notification.ini file I have
use_api_push = yes
api_push_script=/var/lib/zmeventnotification/bin/pushapi_pushover.py
[fcm]
# Use FCM for messaging (default: yes).
enable = no
# Use the new FCM V1 protocol (recommended)
use_fcmv1 = no
# if yes, will replace notifications with the latest one
# default: no
replace_push_messages = no
# Custom FCM API key. Uncomment if you are using
# your own API key (most people will not need to uncomment)
# api_key =
# Auth token store location (default: /var/lib/zmeventnotification/push/tokens.txt).
token_file = {{base_data_path}}/push/tokens.txt
Where should I look for the logs which may give a clue or have I overlooked something ?
Regards Tim
