How to use AMD AMF GPU acceleration for H.265 encoding on ZoneMinder for Ubuntu 22.04?
rajhlinux
Post by rajhlinux »
Hello, I have Ubuntu 22.04 and would like to know how I can setup ZoneMinder to do GPU AMD AMF hardware acceleration for encoding in H.265 / H.264.
I tried doing it in the past and it is super complicated, I need to install tons of drivers and set so many parameters.
Are there any easy to follow guides that shows us how to do this for Ubuntu?
I have AMD Radeon RX 580 and also AMD Radeon Pro WX2100.
Note: VAAPI also does not work on Ubuntu.
Thanks.
Ralphred
Re: How to use AMD AMF GPU acceleration for H.265 encoding on ZoneMinder for Ubuntu 22.04?
Post by Ralphred »
rajhlinux wrote: Mon Jul 04, 2022 3:10 amNote: VAAPI also does not work on Ubuntu.
Do you mean you don't have the right bits installed, like mesa with radeonsi & vaapi support, or ffmpeg is known to "just not work" with vaapi hardware encoders in ubuntu?
Edit: I've a couple of spare machines upstairs, what I don't have is a spare polaris or later card to throw in one and make it work, but initial tests using a VM show ffmpeg and mesa to be "complete"
root@kubuntu:~# ffmpeg -hide_banner -encoders |awk '/VAAPI/&&/26[45]/{print}'
 V....D h264_vaapi           H.264/AVC (VAAPI) (codec h264)
 V....D hevc_vaapi           H.265/HEVC (VAAPI) (codec hevc)
root@kubuntu:~# ffmpeg -hide_banner -init_hw_device list
Supported hardware device types:
vdpau
cuda
vaapi
qsv
drm
opencl
root@kubuntu:~# locate radeonsi_drv_video.so
/usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so
What does your system return if you install and run vainfo?
