Page 1 of 1
Fail2Ban Regex
Posted: Sat Jul 02, 2022 12:58 pm
by clipo
Since ZM 1.35+ the login auth has changed resulting in the default Zoneminder fail2ban Regex no longer working
The below is a working Regex for the jail.local file tested on ZM 1.36.19
This is taken from the below site and placed here for others to find easy.
https://github.com/fail2ban/fail2ban/issues/2643
[zoneminder]
# Zoneminder HTTP/HTTPS web interface auth
# Logs auth failures from /var/log/zm/web_php.log error log
enabled = true
port    = http,https
logpath = /var/log/zm/web_php.log
# Below is the Regex filer that would normally live within the filter.d zoneminder.conf file
filter =
failregex = ^\s*web_php\[\d+\]\.ERR \[<HOST>\].*includes/auth.php
datepattern = ^%%m/%%d/%%y %%H:%%M:%%S(?:\.%%f)
Edit : The above Regex is now taken from the ZM git misc folder.
Re: Fail2Ban Regex
Posted: Mon Jul 18, 2022 11:51 am
by clipo
Starting with 1.36.20 the above Regex will no longer work due to the DATETIME_FORMAT_PATTERN including time zone information and not following the previous pattern as used by ZM
To resolve this enter the following into the Options / System / DATETIME_FORMAT_PATTERN
yyyy/MM/dd HH:mm:ss
And then used the slightly simplified Regex below that has the datepattern removed to allow the Fail2ban built in datepatterns to work.
[zoneminder]
enabled = true
port    = http,https
filter =
l
Re: Fail2Ban Regex
Posted: Mon Nov 21, 2022 8:18 am
by NotSoWittyName
Thanks for this. Just to confirm this is still working with 1.36.31.
Re: Fail2Ban Regex
Posted: Tue Jun 06, 2023 7:52 pm
by clipo
Can anyone confirm that
web_php.log
is the only file that ZM writes access errors too.
