getCmdRespons and socket_sendto Error
NiceAr
Post by NiceAr »
The Linux version I use
Static hostname: DebB
Icon name: computer-desktop
Chassis: desktop
Machine ID:
Boot ID:
Operating System: Debian GNU/Linux 11 (bullseye)
Kernel: Linux 5.10.0-15-amd64
Architecture: x86-64
Zonemainder version:v1.36.18
I have installed zoneminder and run it. I can also see the video stream, but the log will report an error. Here is the code.
These error codes only appear during backtracking.
06/19/22 18:35:19.742173 web_js[734089].ERR [192.168.0.20] [getCmdResponse%20stream%20error%3A%20socket_sendto(%20%2Frun%2Fzm%2Fzms-879662s.sock%20)%20failed%3A%20Connection%20refused%20-%20checkStreamForErrors()] at ?view=event&eid=1125&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=MonitorId&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bop%5D=IN&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bval%5D=1%2C2&filter%5BQuery%5D%5Bsort_asc%5D=1&filter%5BQuery%5D%5Bsort_field%5D=StartDateTime&filter%5BQuery%5D%5Blimit%5D=0&sort_field=StartDateTime&sort_asc=1&page=1 line
 06/19/22 18:35:19.695630 web_php[734089].ERR [192.168.0.20] [socket_sendto( /run/zm/zms-879662s.sock ) failed: Connection refused] at /usr/share/zoneminder/www/includes/functions.php line 1907
Jun 19 18:35:19 DebB zmc_m2[733881]: INF [zmc_m2] [HIKVISION DS-2CD3310D-I: 53800 - Capturing at 25.00 fps, capturing bandwidth 62708bytes/sec Analysing at 0.00 fps]
Who can help me answer this question?
SkippyDo
Re: getCmdRespons and socket_sendto Error
Post by SkippyDo »
Are you using SSL? (recommended)
