[SOLVED] ZoneMinder 1.36.16-focal1 The Memory Remains - USB Monitor can't be created
bkjaya1952
Post by bkjaya1952 »
I have tested the latest ZoneMinder 1.36.16-focal1 The Memory Remains issued today with a local USB Camera .
USB monitor can't be created using the ZM Console .
Screenshot from 2022-05-28 16-27-12.png (238.68 KiB) Viewed 497 times
Screenshot from 2022-05-28 16-26-55.png (332.5 KiB) Viewed 497 times
Re: ZoneMinder 1.36.16-focal1 The Memory Remains - USB Monitor can't be created
You are running Zoneminder on a desktop install. What Linux distro and version? What hardware?
OK, it looks like Ubuntu. If you are on a RPI there is a good chance the USB cam will not work... Have been down that road many times.
I think it’s one of the OP’s standard tests for new releases, so I’d assume it usually works for him.
bkjaya1952
Re: [SOLVED] ZoneMinder 1.36.16-focal1 The Memory Remains - USB Monitor can't be created
Thank you Sir !
for solving the above issue.
I have tested the latest ZoneMinder 1.36.17-focal1 ( The Memory Remains ) issued and found the USB Monitor can be created successfully .
Thanks again for fixing the issue . :D :D
Screenshot from 2022-06-01 20-33-01.png (393.5 KiB) Viewed 391 times
