Recording stops too early
leksand
Post by leksand »
Recording stops too early: there is still movement in the frame - people are walking, the video is not written further.
I tried different buffer modes, now the time setting.
Perhaps the reason is that the motion sensor does not work - if you believe the red stripe at the bottom. The whole screen area, tried different settings from the preset ones, the movement is a human figure.
Andyrh
Re: Recording stops too early
Post by Andyrh »
The blend option will affect how long motion is detected. Also the size of the motion, if it is moving away gets smaller and may fall below your detection limits. There is also the post event frame count that helps.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
