Many errors in log. ERR Socket /run/zm/zms-does not exist
Posted: Thu May 26, 2022 12:17 pm
A huge number of errors appear in the logs - 80+ thousand in a few days for the last time for example.
Linux Debian OS. Originally there was version 1.34, then updated to 1.36.14, now 1.36.15.
022-05-26 15:08:17 web_php 20113 ERR Socket /run/zm/zms-283538s.sock does not exist. This file is created by sms, and since it does not exist, either ms did not run, or zms exited early. Please check your sms logs and ensure that SHE is enabled in apache and check that the PATH_KS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (mc) is not running the sims will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 1907
5 ip 2MP hikvision rtsp 1080p 25 frames + 1 rtsp from rvi dvr
ffmpeg, modest, rtsp tcp, 1080p,
h264 camera pass through, JPEG disabled.
Buffer 3; max 0; I threw processors and memory with a margin - it doesn't help (virtual machine).
dmesg |tail
[ 6004.837063] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/zoneminder.service,task=zmc,pid=19181,uid=33
[ 6004.837123] Out of memory: Killed process 19181 (zmc) total-vm:6679792kB, anon-rss:5955848kB, file-rss:0kB, shmem-rss:24308kB, UID:33 pgtables:12176kB oom_score_adj:0.
After the update, new mass errors:
2022-05-26 15:35:55 zms_m 17 19355 ERROR sdm monitor is not connected zm_stream.cpp 78
2022-05-26 15:35:55 Error zms_m 18 20147 Could not connect to monitor id 18 for streaming zm_stream.cpp 60
2022-05-26 15:35:55 zms_m18 20147 ERROR Cannot open the memory card file /dev/shm/zm.map.18: There is no such file or directory zm_monitor.cpp 927
What can be done, what can be added for diagnostics?
upd: 60 thousand error messages per day
dmesg |tail
