IPC 365 Cameras Invalid Data
rdbates1
Post by rdbates1 »
I've added some IPC 365 motion light cameras and am running into an invalid data error. I can open the stream with VLC rtsp://admin:123456@192.168.0.251:554/live
and probed a test camera with zoneminder and selected a recommended resolution from the probe but am unable to stream the video. What am I missing?
2022-05-25 12:11:30.742444 zmc_m12[27179].ERR-zmc.cpp/257 [Failed to prime capture of initial monitor]
2022-05-25 12:11:30.713382 zmc_m12[27179].ERR-zm_ffmpeg_camera.cpp/394 [Unable to open input rtsp://admin:123456@192.168.0.251:554/realmonitor?channel=0&stream=1.sdp due to: Invalid data found when processing input]
2022-05-25 12:11:16.519613 zmc_m12[27179].ERR-zmc.cpp/257 [Failed to prime capture of initial monitor]
2022-05-25 12:11:16.461936 zmc_m12[27179].ERR-zm_ffmpeg_camera.cpp/394 [Unable to open input rtsp://admin:123456@192.168.0.251:554/realmonitor?channel=0&stream=1.sdp due to: Invalid data found when processing input]
2022-05-25 12:11:02.275922 zmc_m12[27179].ERR-zmc.cpp/257 [Failed to prime capture of initial monitor]
2022-05-25 12:11:02.227588 zmc_m12[27179].ERR-zm_ffmpeg_camera.cpp/394 [Unable to open input rtsp://admin:123456@192.168.0.251:554/realmonitor?channel=0&stream=1.sdp due to: Invalid data found when processing input]
2022-05-25 12:10:47.797141 zmc_m12[27179].ERR-zmc.cpp/257 [Failed to prime capture of initial monitor]
2022-05-25 12:10:47.631112 zmc_m12[27179].ERR-zm_ffmpeg_camera.cpp/394 [Unable to open input rtsp://admin:123456@192.168.0.251:554/realmonitor?channel=0&stream=1.sdp due to: Invalid data found when processing input]
2022-05-25 12:10:33.433797 zmc_m12[27179].ERR-zm_ffmpeg_camera.cpp/394 [Unable to open input rtsp://admin:123456@192.168.0.251:554/realmonitor?channel=0&stream=1.sdp due to: Invalid data found when processing input]
2022-05-25 12:10:29.228004 zmc_m12[27179].INF-zmc.cpp/223 [Starting Capture version 1.34.23]
2022-05-25 12:10:28.598327 zmc_m12[27179].INF-zm_ffmpeg.cpp/84 [Not enabling ffmpeg logs, as LOG_FFMPEG and/or LOG_DEBUG is disabled in options, or this monitor is not part of your debug targets]
2022-05-25 12:10:25.343478 zmc_m12[27010].ERR-zmc.cpp/257 [Failed to prime capture of initial monitor]
2022-05-25 12:10:25.306687 zmc_m12[27010].ERR-zm_ffmpeg_camera.cpp/394 [Unable to open input rtsp://admin:123456@192.168.0.251:554/realmonitor?channel=0&stream=1.sdp due to: Invalid data found when processing input]
