Hi everyone, first post! I've been running 1.34 on bionic for quite some time, and I'm just getting around to updating it. I configured the PPA for 1.36 but it seems like it only offers 1.36.15 at the moment which isn't good for me... is there any way I can upgrade to 1.36.14 instead? I want to stick with apt, I'm not too interested in stuff like building from source.
Reason: I'm facing the known issue described here -- viewtopic.php?p=126426#p126426 -- which I assume (but correct me if I'm wrong) only applies to .15, not .14 and earlier.
Obviously I could instead ask "when will 1.36.16 be released?" but I'm not that rude
Update from 1.34 to 1.36.14 on bionic
Re: Update from 1.34 to 1.36.14 on bionic
You could either use 14 by specifying it, or you could try the working zoneminder proposed .15
Can you give me an example of "specifying it"? This is what I've tried:
root@zoneminder:~# apt-cache policy zoneminder
zoneminder:
Installed: 1.34.26-bionic2
Candidate: 1.36.15-bionic1
Version table:
1.36.15-bionic1 500
500 http://ppa.launchpad.net/iconnor/zoneminder-1.36/ubuntu bionic/main amd64 Packages
*** 1.34.26-bionic2 100
100 /var/lib/dpkg/status
root@zoneminder:~# apt list -a zoneminder
Listing... Done
zoneminder/bionic 1.36.15-bionic1 amd64 [upgradable from: 1.34.26-bionic2]
zoneminder/now 1.34.26-bionic2 amd64 [installed,upgradable to: 1.36.15-bionic1]
root@zoneminder:~# apt-cache madison zoneminder
zoneminder | 1.36.15-bionic1 | http://ppa.launchpad.net/iconnor/zoneminder-1.36/ubuntu bionic/main amd64 Packages
root@zoneminder:~# apt upgrade zoneminder
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
zoneminder : Depends: libswscale5 but it is not installable
Depends: libswresample3 but it is not installable
Depends: libvncclient1 but it is not going to be installed or
libvncclient0 but it is not installable
Depends: libjwt-gnutls0 but it is not installable or
libjwt0 but it is not going to be installed
E: Broken packages
root@zinminder:~# apt upgrade zoneminder=1.36.14-bionic1
E: Version '1.36.14-bionic1' for 'zoneminder' was not found
ugh. Things are in flux. But a new proposed just came up, so see if this works for you...
sudo add-apt-repository ppa:iconnor/zoneminder-proposed
sudo apt update
That should get you 1.36.16~20220525.31-bionic1 , which seems functional, for me, so far.
sudo apt update
Is there a repository where something like `apt upgrade zoneminder=1.36.14-bionic1` would succeed (or at least be attemptable)? I'm just more into stability than pre-release for this particular use case. I'm running inside Proxmox and snapshots aren't working due to the way I have things mounted... I'm going to rebuild from a fresh start at some point to correct that (maybe with Debian, I hear that's better than Ubuntu for Zoneminder lately?) but until then I just want to be super careful.
I usually use the .deb file for older releases that I’m keen to use. Have a look here https://launchpad.net/~iconnor/+archive ... d/23524565
