[SOLVED] Debian Bullseye repo confusion
Posted: Mon May 23, 2022 12:24 pm
Hi there,
we're currently on ZoneMinder 1.36.12 on a Debian Bullseye and want to update to... i think 1.36.14 is latest for amd64 systems. We use in our repo file. works fine and shows zoneminder and zoneminder-doc ready to update. When doing apt tells us
Is this a mistake in your repos or do we miss something at our site?
Thanks for your support and greets
Stephan
deb https://zmrepo.zoneminder.com/debian/release-1.36/bullseye/ /
apt update
apt upgrade
Err:1 https://zmrepo.zoneminder.com/debian/release-1.36/bullseye zoneminder 1.36.14-bullseye1
404 Not Found [IP: 158.69.226.113 443]
Err:2 https://zmrepo.zoneminder.com/debian/release-1.36/bullseye zoneminder-doc 1.36.15-bullseye1
E: Failed to fetch https://zmrepo.zoneminder.com/debian/release-1.36/bullseye/bullseye/zoneminder_1.36.14-bullseye1_amd64.deb 404 Not Found [IP: 158.69.226.113 443]
E: Failed to fetch https://zmrepo.zoneminder.com/debian/release-1.36/bullseye/bullseye/zoneminder-doc_1.36.15-bullseye1_all.deb 404 Not Found [IP: 158.69.226.113 443]
Stephan
