Zoneminder 1.36.15 + zmninja
Kakosan
Post by Kakosan »
Good afternoon. I recently installed zoneminder. Excellent solution, the modes work properly. I decided to test the zmninja application on both IOS and ANDROID. And I ran into a problem, the live stream from the cameras is not displayed. But at the same time, you can view the record by triggers. There are thoughts on how to set up a live stream in the application. Best regards.
Re: Zoneminder 1.36.15 + zmninja
I just checked my Android Zmninja app and it is working on Android. One suggestion is to use a smaller video resolution on ZM. 1080P at the most and even lower if you need to. There is a separate forum area for mobile apps where you may find some tips to get Zmninja working although the config is pretty straight forward.
Ditto bbunge on iOS.
Kakosan
Post by Kakosan »
https://zmninja.readthedocs.io/en/lates ... ing-issues
Here's a solution. Problem solved.
I should change path to CGI-bin in app settings.
