localhost/zm not found
swolsen
Post by swolsen »
Installed Zoneminder on a new system using ppa:iconnor/zoneminder-1.36 All seemed to go well but I am not able to access the web interface.
zmdc.log
05/20/2022 06:32:45.905636 zmdc[1027].INF [ZMServer:411] [Server starting at 22/05/20 06:32:45]
05/20/2022 06:32:46.948969 zmdc[1027].INF [ZMServer:411] [Socket should be open at /run/zm/zmdc.sock]
05/20/2022 06:32:47.165747 zmdc[1027].INF [ZMServer:411] ['zmfilter.pl --filter_id=1 --daemon' starting at 22/05/20 06:32:47, pid = 1191]
05/20/2022 06:32:47.165766 zmdc[1191].INF [ZMServer:411] ['zmfilter.pl --filter_id=1 --daemon' started at 22/05/20 06:32:47]
05/20/2022 06:32:47.216318 zmdc[1198].INF [ZMServer:411] ['zmfilter.pl --filter_id=2 --daemon' started at 22/05/20 06:32:47]
05/20/2022 06:32:47.216317 zmdc[1027].INF [ZMServer:411] ['zmfilter.pl --filter_id=2 --daemon' starting at 22/05/20 06:32:47, pid = 1198]
05/20/2022 06:32:47.268892 zmdc[1027].INF [ZMServer:411] ['zmwatch.pl' starting at 22/05/20 06:32:47, pid = 1204]
05/20/2022 06:32:47.268892 zmdc[1204].INF [ZMServer:411] ['zmwatch.pl' started at 22/05/20 06:32:47]
05/20/2022 06:32:47.321626 zmdc[1027].INF [ZMServer:411] ['zmupdate.pl -c' starting at 22/05/20 06:32:47, pid = 1211]
05/20/2022 06:32:47.321637 zmdc[1211].INF [ZMServer:411] ['zmupdate.pl -c' started at 22/05/20 06:32:47]
05/20/2022 06:32:47.374211 zmdc[1027].INF [ZMServer:411] ['zmstats.pl' starting at 22/05/20 06:32:47, pid = 1216]
05/20/2022 06:32:47.374212 zmdc[1216].INF [ZMServer:411] ['zmstats.pl' started at 22/05/20 06:32:47]
Update agent starting at 22/05/20 06:32:47
I am using Linux Mint 20.3 of which I am running Zoneminder 1.36.15 on another box with no problems except it is under powered.
Re: localhost/zm not found
Wrong logs. It is an Apache config problem if you don’t see the web interface. Makes no difference if ZM is running or not.
Look at the a2en* commands and make sure you’ve run them all.
swolsen
Post by swolsen »
I believe you are correct, however running sudo a2ensite shows only 000-default and default-ssl. Obviously not one for zoneminder. Where or how do I configure zoneminder site?
I thought this was set up automatically??
Nevermind. Got it. Had to enable zoneminder.conf and enable rewrite engine.
Make sure you check a2enconf too. In case it’s an available conf rather than site.
This file will likely work https://github.com/ZoneMinder/zoneminde ... he.conf.in
swolsen
Post by swolsen »
Thank you. My bad!
Glad you have it sorted.
