Testing 1.36.15 - 2 little issues preliminarly found
pat2
Post by pat2 »
ZM 1.36.15 on Odroid XU4, Ubuntu 20.04.
1. in montage view, state is not correct; fps = 0 or blank for each camera
2. for cameras with orientation Rotate Right the zone appears greater than the image
ZM 1.36.34 - 14 cameras on Orange Pi 5 (arm64) - Ubuntu Jammy 22.04
Re: Testing 1.36.15 - 2 little issues preliminarly found
The first sounds like the background ajax call is failing.
The second... this is not a new problem, right? When you change the rotation, we don't update the zone points. Maybe we should but we don't. So yeah, the zones are all out of whack.
pat2
Post by pat2 »
Hi Isaac,
thanks.
For the first, should I do somenthing?
For the second, no, it's not a problem, a reminder. When I change the rotation, ZM doesn't update the zone points. So, the zones are all out of whack. correct.
thanks Michele
