ZM 1.36.15 - Constant Alert in LOG
Posted: Mon May 16, 2022 5:08 pm
Hello, I'm running ZM in Ubuntu 20.04 and was notified that zm 1.36.14 was available thru the Ubuntu software updater. However, after updating, I seem to be on 1.36.15 and now my ZM log is in constant alert with the following messages being repeated every few seconds for web_php and web_js
Date/Time,Component,Server,PID,Level,Message,File,Line
"2022-05-16 09:52:02",web_php,,84234,ERR,"Socket /run/zm/zms-574578s.sock does not exist.
This file is created by zms, and since it does not exist, either zms did not run, or zms
exited early. Please check your zms logs and ensure that CGI is enabled in apache and check
that the PATH_ZMS is set correctly. Make sure that ZM is actually recording.
If you are trying to view a live stream and the capture process (zmc) is not running
then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.",/usr/share/zoneminder/www/includes/functions.php,1908
"2022-05-16 09:51:43",web_js,,96949,ERR,"getStreamCmdResponse stream error:
Socket /run/zm/zms-505864s.sock does not exist.
or zms exited early.
running then zms will exit.
Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information. - checkStreamForErrors()",?view=watch&mid=7,'-
ZM appears to be working fine and is recording and I'm able to view live motion, so I don't know what is going on. Anyone has ideas on this?
Thanks in advance.
Thanks in advance.
