Fatal Error - zmaudit.pl appears to already be running at pid 1144
Pembrae
Post by Pembrae »
I have noticed that following error being logged. Please can anyone advise what the problem is and what I should do to fix it. Thanks
zmaudit.pl appears to already be running at pid 1144. If not, please delete /run/zm/zmaudit.pid or use the --force command line option.
Re: Fatal Error - zmaudit.pl appears to already be running at pid 1144
if zmaudit is in fact not running, then run zmaudit.pl -f
Pembrae
Post by Pembrae »
Thank you for the response.
Not being a competent Linux user I was not sure of how to work out if zmaudit.pl was running, I used HTOP and 'service --status-al' but saw no listing of zmaudit. (Retrospectively I suspect I would have been better using 'top' command).
I executed the 'zmaudit.pl -f' command and got the following response:
pete@pemserv2:~$ zmaudit.pl -f
24/05/22 17:34:21.976626 zmaudit[225351].ERR [main:106] [zmaudit.pl appears to already be running at pid 1144. Continuing.]
24/05/22 17:34:24.928032 zmaudit[225351].INF [main:199] [Auditing All Storage Areas]
Found open event '75791' on Monitor 5 at 2022-05-06 06:48:52, closing
Deleted 10 log table entries by time
Deleted 2 log table entries by time
Deleted 0 log table entries by time
The ZoneMinder log reported the following:
"2022-05-24 17:35:46",zmaudit,,225369,FAT,"zmaudit.pl appears to already be running at pid 225351. If not, please delete /run/zm/zmaudit.pid or use the --force command line option.",zmaudit.pl,'-
"2022-05-24 17:34:24",zmaudit,,225351,INF,"Auditing All Storage Areas",zmaudit.pl,'-
"2022-05-24 17:34:21",zmaudit,,225351,ERR,"zmaudit.pl appears to already be running at pid 1144. Continuing.",zmaudit.pl,'-
Does this mean zmaudit was restarted as a new process with PID 225351 and that I am still getting the effectively the same error message as before except the PID has changed from 1144 to 225351?
I have tried unselected the option to run zmaudit but top is still showing zmaudit.pl running with PID 225351 and I am still getting the 'zmaudit.pl appears to already be running at pid 225351. If not, please delete /run/zm/zmaudit.pid or use the --force command line option' error message.
Please can anyone advice why I am getting this error message and its consequence .
Would be worth restarting ZM since you unticked the option.
If you wish to use htop then -u www-data will show all the ZM stuff that’s running.
Or run
pgrep -fl zm
