Can not set OPT_USE_API after udgrade to 1.37.15_20220504130434-focal_amd64.deb
Posted: Fri May 06, 2022 3:56 pm
Hi all!
Ubuntu Server 20.04 LTS with latest updates.
After upgrading ZM from 1.37.13 to 1.37.15_20220504130434-focal_amd64.deb OPT_USE_API turned itself off.
Any attempts to turn it back on silently end up with OPT_USE_API=0.
The only solution I've found was to downgrade to 1.37.14_20220502095655-focal for a minute just to turn it back on. Then it stays ON until I change anything in /zm/index.php?view=options&tab=system with saving. The parameter I change is saved successfully, but OPT_USE_API turns OFF and no way to change it to ON without doing a "downgrade to 1.37.14 -> turn on OPT_USE_API -> upgrade to 1.37.15" procedure.
Don't think it's normal. Maybe changing this setting in DB Config table would work, I didn't check.
e. g.
e. g.
UPDATE zm.Config SET Value=1 WHERE Name='ZM_OPT_USE_API';
