zoneminder masater 1.37.14~20220501132939-bionic -The istallation problem has been solved
bkjaya1952
Post by bkjaya1952 »
Zoneminder master 1.37.14~20220501132939-bionic can be installed without any problem.
( There was an installation error in the previous version of zoneminder master -bionic , as livalibavdevices58 can't be installed )
Thank you Sir,
for fixing the issue !
Re: zoneminder masater 1.37.14~20220501132939-bionic -The istallation probmen has been solved
My pleasure.
The libavdevice brings support for v4l devices using the ffmpeg monitor type.
