Problems viewing monitors in multiserver setup
aquadot
Post by aquadot »
I just setup a multiserver setup and everything seems to be recording correctly but I am having one problem still. If I try to view monitors from another server the picture doesn't show up and the other server's apache log shows the following error:
[Wed Apr 27 12:21:23.837789 2022] [cgi:error] [pid 1648] [client 10.42.42.2:41782] malformed header from script 'zms': Bad header: HTTP/1.0 403 Forbidden
Any thoughts on what needs fixed?
aquadot
Re: Problems viewing monitors in multiserver setup
Post by aquadot »
I found the solution to my problem. I am using the option "OPT_USE_AUTH" located under Options>System. I had to enable the Options>System>AUTH_HASH_LOGINS
Now I am able to view monitors from either of the two ZoneMinder systems.
