I encountering a lot of issues with playing recorded events.
Especially since upgrading to 1.36 this became very unstable for me. I am running ZM 1.36.14 on a Debian 11 bullseye machine (amongst other services on that server). Live view works without any problem. But when opening an event some play back without any issues and for some I am not getting shown one frame.
The logfile shows errors like these:
"2022-04-26 08:08:24",web_js,,1060452,ERR,"getCmdResponse stream error: Socket /run/zm/zms-384631s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()",?view=event&eid=201596&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=StartDateTime&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bop%5D=%3E%3D&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bval%5D=-1+day&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bcnj%5D=and&filter%5BQuery%5D%5B,'-
"2022-04-26 08:08:24",web_php,,1060452,ERR,"Socket /run/zm/zms-384631s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.",/usr/share/zoneminder/www/includes/functions.php,1904
"2022-04-26 08:08:19",web_js,,1060452,ERR,"getCmdResponse stream error: Socket /run/zm/zms-384631s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()",?view=event&eid=201596&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=StartDateTime&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bop%5D=%3E%3D&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bval%5D=-1+day&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bcnj%5D=and&filter%5BQuery%5D%5B,'-
"2022-04-26 08:08:19",web_php,,1060452,ERR,"Socket /run/zm/zms-384631s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.",/usr/share/zoneminder/www/includes/functions.php,1904
"2022-04-26 08:07:59",zmc_m3,,1026944,INF,"Atrium: 4409000 - Analysing at 19.99 fps from 4408984 - 4407984=1000 / 1650953279.963573 - 1650953229.944773 = 50.018800",zm_monitor.cpp,1715
Please guide me where to dig in as this is really frustrating, especially after using ZM for several years now...
