Best Handheld Vacuums: The Top Choices
Not everybody needs a full-size vacuum cleaner. A compact choice like handheld vacuums should be your priority when handling smaller messes. These machines can still offer plenty of heavy lifting without taking up much storage space.
Of course, these compact vacuums can't replace your full-size upright or stick when you need to do a thorough cleaning around your house. But for pet hair stuck in your furniture, tracked-in dirt, and dry pills, handheld vacuums will come in handy.
On top of typical household messes, they have other uses as well, including cleaning vehicles, garden benches, or keeping your workshop clean.
What are the Best Rated Vacuum Cleaners in this case? Most handheld vacuums these days are cordless models, meaning they use batteries to provide suction power for a limited period of time. Thanks to technology advancements, this battery life has improved tremendously, and handheld vacuums can handle a much larger area than they could many years ago.
They come with many useful features that we used to find only on regular models, such as multiple speeds, removable batteries, or washable filters.
Some handheld vacuums can even remove stains and suck up wet debris just fine. With the help of other attachments, their brushes can dust off mattresses, door frames, window sills, draperies, and other spots that are almost impossible for full-size vacuums to reach.
But the wide variety of handheld options may make new users feel confused when choosing a machine for them. Here are some quick top picks that should be on your list.
1. Worx WX030L Power Share Portable Vacuum Cleaner
From the well-known lawn and garden tool manufacturer Worx, this model doesn't look like a typical handheld vacuum. It has a unique boxy body with a top handheld. The WX030L also features a removable battery that you can use on other power tools from Worx, earning it great best vacuum cleaner reviews.
The 4-feet hose is built-in, while the brush and crevice tools are located right on it. This handheld unit performs well on most surfaces, easily picking up pet hair and debris even when it's not on the maximum power mode.
2. Bissell AeroSlim Cordless Handheld Vacuum
This super-compact handheld from Bissell is the ideal tool when you need to pick up small messes quickly from hard surfaces. With the one-hand operation and the combo of a soft brush and crevice tool, the AeroSlim can deal with crumbs and spills between the cushions of your sofa, in your car, or on your computer's keyboard.
The machine stands upright thanks to the storage base and its built-in cap. It's also where you can store the accessories. There is a USB port for charging and a washable filter as well.
3. Bissell Pet Hair Eraser Hand Vacuum
At under four pounds, this Bissell handheld is extremely lightweight. The rubber nozzle is designed to deal with pet hair. It can flex and contour around stair treads and chair arms to pick up every single strand of hair, making it the best vacuum in the world when it comes to pet hair.
For other dry spills like kitty litter, you can remove this rubber tip and extend the crevice tool. The Bissell Pet Hair Eraser is not a cordless machine. But the 16-feet power cord should be long enough for a handheld machine.
Conclusion
Vacuum manufacturers have made many great handheld vacuums in recent years. If you want to learn about other amazing best vacuum cleaner brands, head to our part two and see if they are the right choice for you.
Problem on zoneminder 1.34.22
Last edited by danielkreger on Wed Jan 10, 2024 10:28 am, edited 2 times in total.
Re: Problem on zoneminder 1.34.22
Do not quite understand your problem. Can you provide a bit more information, please. Also which Linux distro and version. What instructions did you use to install Zoneminder?danielkreger wrote: ↑Tue Apr 12, 2022 3:45 am I am having a problem on zoneminder 1.34.22 every time motion is detected. I think there is a deduplicate trigger sent and cancel another.
Any suggestion? Thanks!
