Console shows Events but listing is empty
lightguy48
Post by lightguy48 »
I have a couple of cameras/sources that are stuck showing events but when you click on the count it says no matching records found. I have zmaudit enabled and thought this would clean these up over time and even did a sql consistency check but nothing seems to reset the counters back to zero.
Is there something else to fix something like this?
Thanks!
lightguy48
Re: Console shows Events but listing is empty
Just pinging this issue again, I have a source/camera and from the the Console in the Hour column it is always showing 12 events, yet when you click on the events it shows no events in the event listing. If there is an event then the counter will increase above twelve, i.e. 2 events in the last hour will list 14 events.
I remember iconnor mentioning something about Zoneminder does something to generate the event counter numbers is there some way to reset / fix the counter back to zero?
I expect it's done by a trigger. If zmaudit doesn't clean it up you'd have to dig into the DB.
lightguy48
Ok thanks, unfortunately I have no idea where to even start to go about fixing a record in the database.
Have you already run zmaudit?
lightguy48
Well huh... I thought ZM Audit was enabled, but I went and checked settings and it was unchecked... running now... :?
I just assumed it was running in the background... will post back if it cleans up the issue.
There was a time when it ran in the background and that was the recommended way. Some point later on the advice changed. I leave mine unticked and just manually run the command every now and then when I think of it.
lightguy48
Well it took several hours but it finally cleared it to zero.
Thanks for the tip, I'm trying to remember to run it manually you just do zm_audit.pl from a command line?
Yes, but I have a feeling it doesn’t contain underscore.
