pain with Error check failed: '401 Authorization Required'
zonepi
Post by zonepi »
Camera is DCS-5030l
Control tab:
-----Controllable [checked]
-----Control Type DLink DCS-5020L
-----Control Device <blank>
-----Control address:admin:<valid password>@192.168.1.197
it started out by working with presets for 1,2,3,4
I changed the name and then it stopped working, deleted and rebuilt monitor from scratch, factory reset camera, still won't work.
(also trying to use wireshark to get a packet capture of the user:pass handshake... no luck so far
LOGS:
When i monitor the log and try any of the links this appears:
tail -f zmcontrol_12.log
03/09/2022 16:15:52.305369 zmcontrol_12[165049].INF [main:127] [Control server 12/DCS5020L starting at 22/03/09 16:15:52]
03/09/2022 16:16:11.548292 zmcontrol_12[165049].ERR [ZoneMinder::Control::DCS5020L:81] [Error check failed: '401 Authorization Required']
03/09/2022 16:43:53.151188 zmcontrol_12[165049].ERR [ZoneMinder::Control::DCS5020L:81] [Error check failed: '401 Authorization Required']
03/09/2022 16:43:58.981572 zmcontrol_12[165049].ERR [ZoneMinder::Control::DCS5020L:81] [Error check failed: '401 Authorization Required']
Any help appreciated!
zonepi
Re: pain with Error check failed: '401 Authorization Required'
Post by zonepi »
.. any thoughts or comments would help....
the tshark showing any thing so i don't know why i get the 401....
thanks
