Hi
I updated to ZM 1.36 and now I notice, that there is a list of monitors on the left when cycling.. this uses a lot of space on my screen. Any idea how to disable this monitor list? Did not found anything in the forum nor setting..
Thanks!
Cycle view changed in 1.36
Re: Cycle view changed in 1.36
Hi
That's my - limited way - of doing it with a patch
--- cycle.php.orig 2022-06-09 15:24:17.127831601 +0200
+++ cycle.php 2022-06-09 15:36:36.486131839 +0200
@@ -160,18 +160,7 @@
</div>
</div>
<div class="container-fluid h-100">
- <div class="row flex-nowrap h-100" id="content">
- <nav id="sidebar" class="h-100">
- <ul class="nav nav-pills flex-column h-100">
- <?php
- foreach ( $monitors as $m ) {
- echo '<li class="nav-item"><a class="nav-link'.( $m->Id() == $monitor->Id() ? ' active' : '' ).'" href="?view=cycle&mid='.$m->Id().'">'.$m->Name().'</a></li>';
- </ul>
- </nav>
- <div class="container-fluid col-sm-offset-2 h-100 pr-0">
+ <div class="row h-100" id="content">
<div id="imageFeed">
<?php
if ( $monitor ) {
@@ -189,7 +178,6 @@
<button type="button" value=">" id="nextBtn" title="<?php echo translate('NextMonitor') ?>" class="active" data-on-click-true="cycleNext">>></button>
</div>
- </div>
</div>
</div>
<?php xhtmlFooter() ?>
