Bug: Can't delete bigger amount of events at the same time
JariR
Post by JariR »
Noticed that there is a bug on events page when trying to delete all listed events at the same time. Even I've selected events list to show "ALL" events from dropdown menu at the bottom of the page and using select all check box, the maximum amount of deleted events will be 300 events at the one time.
I think there are also couple of usability issues on 1.36.12 version vs. 1.34.x version:
- Delete events-button should be displayed at the bottom of the page or it coulbe in both: above and under the events list
- Events selecting checkboxes should appear next to event thumbnail. This would make using easier with mobile device where horizontal scrolling of page is now required if user firs selects all events and will next unselect some single events based to thumbnail image to not to be deleted
- Displayed events count dropdown menu should be displayed above the the events list. It is difficult to see any reason for why it is now displayed below the events list as it is now.
- On event playback view can't pinch-to-zoom player image to be displayed fully by mobile device (Android, Chrome, OnePlus Nord). It's only showing a part of real image bounds.
