v1.37.11, zmrepo/master, debian
jyrkipes
Post by jyrkipes »
First, humble thank You!
I know I'm on thin ice with /master but been riding the bleeding edge happily as long as I remember so minor breakage hasn't bothered.
user@avalon:~$ sudo apt policy zoneminder
[sudo] user-user password:
zoneminder:
  Installed: 1.37.11~20220202.73-bullseye
user@avalon:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description:    Debian GNU/Linux 11 (bullseye)
Release:        11
Codename:       bullseye
Yesterday something bigger came in and assume it's related to this:
Replace function concept #3420
Looks like all my cameras are now down and I cannot reconfigure or save new selections on
- Capturing: None/Always/Ondemand
- Recording: None/Onmotion/Always
- Analyzing: None/Always
Actually, just not changing anything and hitting Save gives always the one below.
If I hit save, will get sql-related mess:
SQL-ERR '00000 ', statement was 'UPDATE `Monitors` SET `Id`=?, `Name`=?, `Notes`=?, `ServerId`=?, `StorageId`=?, `ManufacturerId`=?, `ModelId`=?, `Type`=?, `Capturing`=?, `Analysing`=?, `Recording`=?, `Enabled`=?, `DecodingEnabled`=?, `JanusEnabled`=?, `JanusAudioEnabled`=?, `LinkedMonitors`=?, `Triggers`=?, `EventStartCommand`=?, `EventEndCommand`=?, `ONVIF_URL`=?, `ONVIF_Username`=?, `ONVIF_Password`=?, `ONVIF_Options`=?, `ONVIF_Event_Listener`=?, `use_Amcrest_API`=?, `Device`=?, `Channel`=?, `Format`=?, `V4LMultiBuffer`=?, `V4LCapturesPerFrame`=?, `Protocol`=?, `Method`=?, `Host`=?, `Port`=?, `SubPath`=?, `Path`=?, `SecondPath`=?, `Options`=?, `User`=?, `Pass`=?, `Width`=?, `Height`=?, `Colours`=?, `Palette`=?, `Orientation`=?, `Deinterlacing`=?, `DecoderHWAccelName`=?, `DecoderHWAccelDevice`=?, `SaveJPEGs`=?, `VideoWriter`=?, `OutputCodec`=?, `Encoder`=?, `OutputContainer`=?, `EncoderParameters`=?, `RecordAudio`=?, `OutputSourceStream`=?, `RTSPDescribe`=?, `Brightness`=?, `Contrast`=?, `Hue`=?, `Colour`=?, `EventPrefix`=?, `LabelFormat`=?, `LabelX`=?, `LabelY`=?, `LabelSize`=?, `ImageBufferCount`=?, `MaxImageBufferCount`=?, `WarmupCount`=?, `PreEventCount`=?, `PostEventCount`=?, `StreamReplayBuffer`=?, `AlarmFrameCount`=?, `SectionLength`=?, `MinSectionLength`=?, `FrameSkip`=?, `MotionFrameSkip`=?, `AnalysisFPSLimit`=?, `AnalysisUpdateDelay`=?, `MaxFPS`=?, `AlarmMaxFPS`=?, `FPSReportInterval`=?, `RefBlendPerc`=?, `AlarmRefBlendPerc`=?, `Controllable`=?, `ControlId`=?, `ControlDevice`=?, `ControlAddress`=?, `AutoStopTimeout`=?, `TrackMotion`=?, `TrackDelay`=?, `ReturnLocation`=?, `ReturnDelay`=?, `ModectDuringPTZ`=?, `DefaultRate`=?, `DefaultScale`=?, `SignalCheckPoints`=?, `SignalCheckColour`=?, `WebColour`=?, `Exif`=?, `Sequence`=?, `ZoneCount`=?, `Refresh`=?, `DefaultCodec`=?, `Latitude`=?, `Longitude`=?, `RTSPServer`=?, `RTSPStreamName`=?, `Importance`=? WHERE Id=?'
Earlier yesterday (GMT-2/Helsinki) lost streaming/viewing thru web -interface, lot of old classic "If you cannot see pics see this FAQ" and recently after .73 kicked in, this:
Memory map file '/dev/shm/zm.mmap.20' does not exist in zmMemAttach. zmc might not be running
to all cameras.
So I think, something-something broke streaming and then this new way of handling camera source broke something more.
Anyway, keep up good, my 0.02cents.
(Will send actual cents from my next paycheck.)
Jyrki, "Dum spiro, spero"
Re: v1.37.11, zmrepo/master, debian
Yeah that's a big problem, and I think I already have it fixed, new proper master packages should have built this morning.
jyrkipes
Post by jyrkipes »
Excellent!
Did update {apt update & upgrade] to .83,
- web streaming of old events started working
- image icons good again
- cannot save, gives previous sql error
- cannot record/mocord/analyse
went to
/usr/share/zoneminder/db
and found this that had the missing Capturing -column update (and maybe others), and what I assume did not run (as should?) when sudo zmupdate.pl
Gave a command:
sudo mysql -usqluser -psqluserpassword zm < zm_update-1.37.multistream.sql
Did restart from webui
And it works!
