Stream and record starting with motion detection?
Posted: Thu Jan 13, 2022 11:37 am
i experimented a few things with Zoneminder and i like Zoneminder and the functions but one thing preoccupies me. I use two types of monitors (one high resolution for motion detection and one low resolution stream for recording). So good so far. But the CPU load is higher with the high resolution stream although Zoneminder doesn't record anything. The pre image buffer is set to 0 but it seems that Zoneminder start both streams and start the recording if any kind of motion is detected. Is there any solution to start the high resolution stream only if there is a motion detection?
Best regards
Best regards
