Advice for deployment - a stable install of 1.36?
texastexas
Post by texastexas »
I'm a ZM newbie. I'm passable with linux/unix.
I loved playing with it a few weeks ago when I tried my first download.
Now, I'm getting ready to deploy a version for real life use. So far, I haven't found anything that just works. I'm not adverse to fiddling, if I get something at the other end that is robust. I feel like every time I fiddle with ZM, something else is a breaks.
I just did a fresh install of 1.36.8 on Ubuntu sever focal. I followed exactly:
https://bkjaya.wordpress.com/2021/05/15 ... cal-fossa/
And there are memory problems and:
10/15/2021 13:14:20.053439 zmdc[1282].INF [ZMServer:411] ['zmc -m 1' starting at 21/10/15 13:14:20, pid = 3953]
10/15/2021 13:14:20.053449 zmdc[3953].INF [ZMServer:411] ['zmc -m 1' started at 21/10/15 13:14:20]
10/15/2021 13:15:03.844450 zmdc[1282].INF [ZMServer:706] ['zmc -m 1' crashed, signal 8]
Events fail after one second.
I tried to follow:
https://wiki.zoneminder.com/Ubuntu_Serv ... der_1.36.x
but the mods to the mysql conf were fatal in my case and I'm not good enough at mysql to run down the problems
Is there an install of a recent version of ZM (preferable 1.36) that's pretty bulletproof?
Re: Advice for deployment - a stable install of 1.36?
Drop out the database tweaks and then work through any remaining problems. It’s might not be 100% plug and play, but it’s not bad.
The instructions for 1.36 havn't changed since 1.34.
https://www.youtube.com/watch?v=RhBsW8HkOG4
Just type 1.36 instead of 1.34 wherever appropriate.
junior466
Post by junior466 »
I am having the exact same problem and been pulling my hair out lately. Constant
in the logs.
Any ideas?
kitkat
Post by kitkat »
texastexas wrote: Fri Oct 15, 2021 8:16 pm I tried to follow:
There are errors in that guide which will very probably stop MySQL/Mariadb from starting: innodb_buffer_pool_ size shouldn't have a space in it, and innodb_log_file_size - 32M should be innodb_log_file_size = 32M (equals instead of minus)
Also, changing innodb_log_file_size can often prevent the service starting or the InnoDB handler/driver loading if you don't get rid of the old logs first.
Check the database log (/var/log/mariadb/mariadb.log) for errors along the lines of
InnoDB: Error: log file ./ib_logfile0 is of different size 0 123456789  bytes
InnoDB: than specified in the .cnf file 0 987654321 bytes!
You can probably fix this (works for me) by:
Stopping the mariadb service (systemctl stop mariadb).
Deleting (or moving/renaming) the old log files (mv /var/lib/mysql/ib_logfile[01] /tmp/)
Starting mariadb (systemctl start mariadb)
Check the log again and you should see a warning that the log files are missing and that they're being recreated.
