NPH ZMS No Stream Using User Pass in URL
RusFM
Post by RusFM »
Hello fellow ZMers,
I just upgraded from 1.34 to 1.36.6 on Ubuntu 18.04.5 LTS.
My live streams referenced from another web server have stopped working. The URLs look like-
https://zoneminder.mydomain.local/zm/cgi-bin/nph-zms?mode=jpeg&monitor=5&scale=40&user=user&pass=password
The live streams within ZM work fine.
When I enable debugging on ZMS I don't see any errors, but it never sends any frames.
Thanks in advance,
Rus
Debug log (partial)-
09/10/21 15:37:08.288636 zms[9791].DB1-zm_logger.cpp/232 [LogOpts: level=DB9 effective=DB9, screen=OFF, database=ERR, logfile=DB9->/var/log/zm/zm_debug.log.09791, syslog=WAR]
09/10/21 15:37:08.288986 zms[9791].DB1-zms.cpp/94 [env: HTTPS=on]
09/10/21 15:37:08.289012 zms[9791].DB1-zms.cpp/94 [env: SSL_TLS_SNI=zoneminder.mydomain.local]
09/10/21 15:37:08.289029 zms[9791].DB1-zms.cpp/94 [env: HTTP_HOST=zoneminder.mydomain.local]
09/10/21 15:37:08.289044 zms[9791].DB1-zms.cpp/94 [env: HTTP_CONNECTION=keep-alive]
09/10/21 15:37:08.289061 zms[9791].DB1-zms.cpp/94 [env: HTTP_SEC_CH_UA=" Not A;Brand";v="99", "Chromium";v="92", "Opera";v="78"]
09/10/21 15:37:08.289076 zms[9791].DB1-zms.cpp/94 [env: HTTP_SEC_CH_UA_MOBILE=?0]
09/10/21 15:37:08.289094 zms[9791].DB1-zms.cpp/94 [env: HTTP_UPGRADE_INSECURE_REQUESTS=1]
09/10/21 15:37:08.289111 zms[9791].DB1-zms.cpp/94 [env: HTTP_USER_AGENT=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.159 Safari/537.36 OPR/78.0.4093.184]
09/10/21 15:37:08.289440 zms[9791].DB1-zms.cpp/94 [env: HTTP_ACCEPT=text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9]
09/10/21 15:37:08.289483 zms[9791].DB1-zms.cpp/94 [env: HTTP_SEC_FETCH_SITE=none]
09/10/21 15:37:08.289522 zms[9791].DB1-zms.cpp/94 [env: HTTP_SEC_FETCH_MODE=navigate]
09/10/21 15:37:08.289543 zms[9791].DB1-zms.cpp/94 [env: HTTP_SEC_FETCH_USER=?1]
09/10/21 15:37:08.289561 zms[9791].DB1-zms.cpp/94 [env: HTTP_SEC_FETCH_DEST=document]
09/10/21 15:37:08.289578 zms[9791].DB1-zms.cpp/94 [env: HTTP_ACCEPT_ENCODING=gzip, deflate, br]
09/10/21 15:37:08.289594 zms[9791].DB1-zms.cpp/94 [env: HTTP_ACCEPT_LANGUAGE=en-US,en;q=0.9]
09/10/21 15:37:08.289612 zms[9791].DB1-zms.cpp/94 [env: HTTP_COOKIE=zmSkin=classic; zmCSS=classic; zmEventsTable.bs.table.columns=%5B%22Id%22%2C%22Name%22%2C%22Monitor%22%2C%22Cause%22%2C%22StartDateTime%22%2C%22EndDateTime%22%2C%22Length%22%2C%22Frames%22%2C%22AlarmFrames%22%2C%22TotScore%22%2C%22AvgScore%22%2C%22MaxScore%22%2C%22Storage%22%2C%22DiskSpace%22%5D; zmEventsTable.bs.table.pageNumber=1; zmEventsTable.bs.table.searchText=; zmEventsTable.bs.table.pageList=All; zmMontageLayout=1; _ga=GA1.2.1627664784.1581370201; zmMontageHeight=; zmMontageWidth=; zmMontageScale=50; replayMode=none; zmWatchScale5=100; zmWatchScale14=100; zmWatchScale13=100; zmEventRate=100; zmWatchScale9=100; zmSkin=classic; zmCSS=classic; zmHeaderFlip=down; ZMSESSID=bl10q5gaei9r1vnh8ct24qc3f0]
09/10/21 15:37:08.289629 zms[9791].DB1-zms.cpp/94 [env: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin]
09/10/21 15:37:08.289646 zms[9791].DB1-zms.cpp/94 [env: SERVER_SIGNATURE=<address>Apache/2.4.29 (Ubuntu) Server at zoneminder.mydomain.local Port 443</address>
09/10/21 15:37:08.289663 zms[9791].DB1-zms.cpp/94 [env: SERVER_SOFTWARE=Apache/2.4.29 (Ubuntu)]
09/10/21 15:37:08.289680 zms[9791].DB1-zms.cpp/94 [env: SERVER_NAME=zoneminder.mydomain.local]
09/10/21 15:37:08.289696 zms[9791].DB1-zms.cpp/94 [env: SERVER_ADDR=192.168.0.24]
09/10/21 15:37:08.289712 zms[9791].DB1-zms.cpp/94 [env: SERVER_PORT=443]
09/10/21 15:37:08.289731 zms[9791].DB1-zms.cpp/94 [env: REMOTE_ADDR=192.168.0.13]
09/10/21 15:37:08.289772 zms[9791].DB1-zms.cpp/94 [env: DOCUMENT_ROOT=/var/www/html]
09/10/21 15:37:08.289871 zms[9791].DB1-zms.cpp/94 [env: REQUEST_SCHEME=https]
09/10/21 15:37:08.289916 zms[9791].DB1-zms.cpp/94 [env: CONTEXT_PREFIX=/zm/cgi-bin]
09/10/21 15:37:08.289938 zms[9791].DB1-zms.cpp/94 [env: CONTEXT_DOCUMENT_ROOT=/usr/lib/zoneminder/cgi-bin]
09/10/21 15:37:08.289956 zms[9791].DB1-zms.cpp/94 [env: SERVER_ADMIN=systems@zoneminder.mydomain.com]
09/10/21 15:37:08.289973 zms[9791].DB1-zms.cpp/94 [env: SCRIPT_FILENAME=/usr/lib/zoneminder/cgi-bin/nph-zms]
09/10/21 15:37:08.290010 zms[9791].DB1-zms.cpp/94 [env: REMOTE_PORT=63535]
09/10/21 15:37:08.290050 zms[9791].DB1-zms.cpp/94 [env: GATEWAY_INTERFACE=CGI/1.1]
09/10/21 15:37:08.290069 zms[9791].DB1-zms.cpp/94 [env: SERVER_PROTOCOL=HTTP/1.1]
09/10/21 15:37:08.290086 zms[9791].DB1-zms.cpp/94 [env: REQUEST_METHOD=GET]
09/10/21 15:37:08.290145 zms[9791].DB1-zms.cpp/94 [env: QUERY_STRING=mode=jpeg&monitor=5&buffer=10&scale=40&user=user&pass=password]
09/10/21 15:37:08.290170 zms[9791].DB1-zms.cpp/94 [env: REQUEST_URI=/zm/cgi-bin/nph-zms?mode=jpeg&monitor=5&buffer=10&scale=40&user=user&pass=password]
09/10/21 15:37:08.290226 zms[9791].DB1-zms.cpp/94 [env: SCRIPT_NAME=/zm/cgi-bin/nph-zms]
09/10/21 15:37:08.290242 zms[9791].DB1-zms.cpp/103 [Query: mode=jpeg&monitor=5&buffer=10&scale=40&user=user&pass=password]
09/10/21 15:37:08.290280 zms[9791].DB1-zms.cpp/180 [Have password for password]
09/10/21 15:37:08.290479 zms_m5[9791].DB1-zm_logger.cpp/232 [LogOpts: level=DB9 effective=DB9, screen=OFF, database=ERR, logfile=DB9->/var/log/zm/zm_debug.log.09791, syslog=WAR]
09/10/21 15:37:08.291441 zms_m5[9791].DB1-zm_crypt.cpp/195 [user is using a bcrypt encoded password]
09/10/21 15:37:08.433795 zms_m5[9791].INF-zm_user.cpp/127 [Authenticated user 'user']
09/10/21 15:37:08.433858 zms_m5[9791].DB1-zm_utils.cpp/201 [Detected a x86\x86-64 processor with AVX]
09/10/21 15:37:08.433883 zms_m5[9791].DB4-zm_image.cpp/389 [Blend: Using SSE2 fast blend function]
09/10/21 15:37:08.433892 zms_m5[9791].DB4-zm_image.cpp/451 [Delta: Using SSSE3 delta functions]
09/10/21 15:37:08.433900 zms_m5[9791].DB4-zm_image.cpp/552 [Deinterlace: Using standard functions]
09/10/21 15:37:08.433906 zms_m5[9791].DB4-zm_image.cpp/565 [Image buffer copy: Using standard memcpy]
09/10/21 15:37:08.434350 zms_m5[9791].DB2-zm_stream.h/217 [Setting replay_rate 100]
09/10/21 15:37:08.435722 zms_m5[9791].DB5-zm_db.cpp/165 [Success]
09/10/21 15:37:08.435792 zms_m5[9791].DB2-zm_storage.cpp/62 [Loading Storage for 1 using SELECT `Id`, `Name`, `Path`, `Type`, `Scheme` FROM `Storage` WHERE `Id`=1]
09/10/21 15:37:08.436364 zms_m5[9791].DB5-zm_db.cpp/165 [Success]
09/10/21 15:37:08.436428 zms_m5[9791].DB1-zm_storage.cpp/80 [Loaded Storage area 1 'Default']
09/10/21 15:37:08.436462 zms_m5[9791].DB1-zm_monitor.cpp/482 [Have camera type Ffmpeg]
09/10/21 15:37:08.436487 zms_m5[9791].DB1-zm_monitor.cpp/2322 [Reloading linked monitors for monitor Driveway, '(null)']
09/10/21 15:37:08.436520 zms_m5[9791].DB1-zm_packetqueue.cpp/662 [Setting pre_event_video_packet_count to 40]
09/10/21 15:37:08.436550 zms_m5[9791].DB1-zm_packetqueue.cpp/656 [Setting max_video_packet_count to 100]
09/10/21 15:37:08.436574 zms_m5[9791].DB1-zm_monitor.cpp/644 [mem.size(8) SharedData=760 TriggerData=560 VideoStoreData=4128 timestamps=48 images=3x2764800 = 8294400 total=8299960]
09/10/21 15:37:08.436601 zms_m5[9791].DB1-zm_monitor.cpp/682 [Loaded monitor 5(Driveway), 0 zones]
09/10/21 15:37:08.436625 zms_m5[9791].DB3-zm_monitor.cpp/906 [Connecting to monitor.  Purpose is 0]
09/10/21 15:37:08.436675 zms_m5[9791].DB3-zm_monitor.cpp/919 [Success opening mmap file at (/dev/shm/zm.mmap.5)]
09/10/21 15:37:08.436704 zms_m5[9791].DB3-zm_monitor.cpp/952 [MMap file size is 8299960]
09/10/21 15:37:08.437977 zms_m5[9791].DB3-zm_monitor.cpp/993 [Aligning shared memory images to the next 64 byte boundary]
09/10/21 15:37:08.438018 zms_m5[9791].DB2-zm_camera.cpp/69 [New camera id: 5 width: 1280 line size: 3840 height: 720 colours: 3 subpixelorder: 6 capture: 0]
09/10/21 15:37:08.438039 zms_m5[9791].DB3-zm_monitor.cpp/1003 [Allocated 3 3 image buffers]
09/10/21 15:37:08.438052 zms_m5[9791].DB3-zm_monitor.cpp/1056 [Success connecting]
09/10/21 15:37:08.438064 zms_m5[9791].DB3-zm_stream.cpp/391 [comms open at ]
09/10/21 15:37:08.438083 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.438105 zms_m5[9791].DB3-zm_stream.cpp/98 [FPS:14.99, MaxFPS:10.00, BaseFPS:14.99, EffectiveFPS:14.99, FrameMod:1, replay_rate(100)]
09/10/21 15:37:08.438117 zms_m5[9791].DB3-zm_stream.cpp/105 [Changing fps to be < max 10.00 EffectiveFPS:7.49, FrameMod:2]
09/10/21 15:37:08.438125 zms_m5[9791].DB2-zm_monitorstream.cpp/569 [Not using playback_buffer]
09/10/21 15:37:08.438132 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.438155 zms_m5[9791].DB2-zm_monitorstream.cpp/704 [Sending frame index: 2: frame_mod: 2 frame count: 0 paused(0) delayed(0)]
09/10/21 15:37:08.438171 zms_m5[9791].DB3-zm_stream.cpp/184 [Scaling by 40, zooming by 100 = magnifying by 40(40)
Last scaling by 100, zooming by 100 = magnifying by 100(100)
Base image width = 1280, height = 720
Virtual image width = 512, height = 288
Last virtual image width = 1280, height = 720
Actual image width = 512, height = 288
Last actual image width = 1280, height = 720
Display image width = 512, height = 288
Last display image width = 1280, height = 720
Send image width = 512, height = 288
Last send image width = 1280, height = 720
09/10/21 15:37:08.438185 zms_m5[9791].DB3-zm_stream.cpp/187 [Magnifying by 40]
09/10/21 15:37:08.442571 zms_m5[9791].DB3-zm_stream.cpp/195 [Real image width = 512, height = 288]
09/10/21 15:37:08.444632 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:08.478234 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.478382 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:08.511931 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.512059 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:08.545617 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.545743 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:08.579248 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.579352 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:08.613112 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.613673 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:08.647262 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.647418 zms_m5[9791].DB3-zm_monitorstream.cpp/795 [Waiting for capture last_write_index=2]
09/10/21 15:37:08.647447 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:08.680932 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.681050 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:08.715236 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.715347 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:08.748880 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.748994 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:08.782510 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.782617 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:08.816181 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.816310 zms_m5[9791].DB3-zm_monitorstream.cpp/795 [Waiting for capture last_write_index=2]
09/10/21 15:37:08.816342 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:08.849869 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.850002 zms_m5[9791].DB3-zm_monitorstream.cpp/795 [Waiting for capture last_write_index=2]
09/10/21 15:37:08.850026 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:08.883544 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.883683 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:08.917400 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.917690 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:08.951293 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.951430 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:08.984956 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302628 - 1631302628 = 0  < 5.000000]
09/10/21 15:37:08.985063 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.018563 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302628 = 1  < 5.000000]
09/10/21 15:37:09.018689 zms_m5[9791].DB3-zm_monitorstream.cpp/795 [Waiting for capture last_write_index=2]
09/10/21 15:37:09.018719 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.052208 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302629 = 0  < 5.000000]
09/10/21 15:37:09.052316 zms_m5[9791].DB3-zm_monitorstream.cpp/795 [Waiting for capture last_write_index=2]
09/10/21 15:37:09.052341 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.086150 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302629 = 0  < 5.000000]
09/10/21 15:37:09.086268 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.119771 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302629 = 0  < 5.000000]
09/10/21 15:37:09.119889 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.153473 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302629 = 0  < 5.000000]
09/10/21 15:37:09.153613 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.187089 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302629 = 0  < 5.000000]
09/10/21 15:37:09.187160 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.220633 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302629 = 0  < 5.000000]
09/10/21 15:37:09.220705 zms_m5[9791].DB3-zm_monitorstream.cpp/795 [Waiting for capture last_write_index=2]
09/10/21 15:37:09.220716 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.254192 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302629 = 0  < 5.000000]
09/10/21 15:37:09.254336 zms_m5[9791].DB3-zm_monitorstream.cpp/795 [Waiting for capture last_write_index=2]
09/10/21 15:37:09.254387 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.287892 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302629 = 0  < 5.000000]
09/10/21 15:37:09.287998 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.321560 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302629 = 0  < 5.000000]
09/10/21 15:37:09.321670 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.355231 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302629 = 0  < 5.000000]
09/10/21 15:37:09.355339 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.388847 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302629 = 0  < 5.000000]
09/10/21 15:37:09.388958 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.422563 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302629 = 0  < 5.000000]
09/10/21 15:37:09.422673 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.456167 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302629 = 0  < 5.000000]
09/10/21 15:37:09.456279 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.489795 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302629 = 0  < 5.000000]
09/10/21 15:37:09.489921 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.523434 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302629 = 0  < 5.000000]
09/10/21 15:37:09.523539 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.557074 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302629 = 0  < 5.000000]
09/10/21 15:37:09.557221 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
09/10/21 15:37:09.590832 zms_m5[9791].DB3-zm_monitor.h/446 [Shared data is valid, checking heartbeat 1631302629 - 1631302629 = 0  < 5.000000]
09/10/21 15:37:09.590952 zms_m5[9791].DB3-zm_monitorstream.cpp/804 [Sleeping for 33364us]
It just keeps going like this.
Re: NPH ZMS No Stream Using User Pass in URL
I introduced a bug unfortunately. I'll be releasing 1.36.7 today to fix it.
You might try adding a maxfps=30 to the url which might work around it for now.
RusFM
Post by RusFM »
That worked. Thanks for the work-around Isaac!
Rus
