unexplained error for deleted camera
FredZ
Post by FredZ »
Hi all
I setup a camera/console with controls (PTZ) and have since removed that camera/console. However I am getting an error in the logs relating to the deleted camera.
2021-07-20 16:36:36	zmdc		632	ERR	'zmcontrol.pl --id 5' exited abnormally, exit status 255	zmdc.pl
2021-07-20 16:36:36	zmcontrol_5		30476	FAT	Unable to load control data for monitor 5	zmcontrol.pl
2021-07-20 16:26:35	zmdc		632	ERR	'zmcontrol.pl --id 5' exited abnormally, exit status 255	zmdc.pl
2021-07-20 16:26:35	zmcontrol_5		29399	FAT	Unable to load control data for monitor 5
How can I resolve this error that should not exist.
Regards
Fred
Re: unexplained error for deleted camera
Maybe you've tried this, but try re-add the cam, add/remove the controls, then remove the cam again.
Yeah, you shouldn't have to...and it may not work anyway.
You may have to delete Monitor 5 record from the DB manually to fix it.
SteveGilvarry
Post by SteveGilvarry »
Apologies but I have to ask. Did you restart ZoneMinder after the deletion? I believe the daemon setup occurs during start-up so might end up with an orphan process.
FredZ
Post by FredZ »
Problem solved
Thank you for the restart advice. I had restarted ZM, but it seems I needed to restart and entire ZM appliance (VM).
Regards
Fred
