Page 1 of 1
A Linked monitor will not trigger an upstream monitor after zone changes
Posted: Mon Jun 21, 2021 1:23 pm
by lk777
I am experiencing the following issue with the linked monitors.
My setup:
A High Resolution monitor (Nodect): Linked Monitor - Low Resolution (Modect) *(Storage JPEGS, Video writer - disabled).
Everything works until I change/add zones on the Low Resolution monitor. It will not trigger a High Resolution monitor any longer after these changes.
And only zoneminder service restart fixes it.
Re: A Linked monitor will not trigger an upstream monitor after zone changes
Posted: Mon Jun 21, 2021 8:48 pm
by iconnor
What version of ZM? I fixed an issue like this back during 1.35 development, but am fairly confident in the code now.
Posted: Wed Jun 23, 2021 12:12 pm
by lk777
Ubuntu 20.04 LXD container (a host 20.04 as well)
ZM 1.36.4
Posted: Wed Jun 23, 2021 6:54 pm
by lk777
And one more.
Just do not want to start a new topic:
Ubuntu
/usr/share/zoneminder/www/api
not all files have the right ownership, at least, in my installation they were root:root instead of www-data:www-data
It flooded logs with the cake permissions errors.
Posted: Wed Jul 07, 2021 7:55 pm
by lk777
Update:
Now it is v1.36.5
It is not only changing zones (as I initially thought) but even opening/closing zones breaks monitors link.
Posted: Fri Jul 23, 2021 10:45 pm
by dangelsaurus
same issue here. linked monitors work fine until you change the motion zone in the lower res monitor... v1.36.5
Posted: Sat Jul 24, 2021 6:45 am
by Magic919
It has been mentioned on a few threads. Either a ZM restart or a change of the monitor type (then change back) will sort it.
Posted: Sun Jul 25, 2021 2:56 am
by dangelsaurus
thanks Magic, that's reasonable. I'll give that a shot. Still a little new to ZM
