Event Notification Server error
Posted: Wed Jun 16, 2021 11:36 pm
Hi all,
Just installed the event notification server today (first time user of it).
All seems to have installed ok, and in zmninjapro, it's connected to the event server.
All is well until an event occurs, at which point the following errors gets thrown into the log:
Component is zmesdetect_m1, level is FAT..
Unrecoverable error:Expecting value: line 1 column 1 (char 0) Traceback:Traceback (most recent call last): File "/var/lib/zmeventnotification/bin/zm_detect.py", line 556, in main_handler() File "/var/lib/zmeventnotification/bin/zm_detect.py", line 335, in main_handler zmapi = zmapi.ZMApi(options=api_options) File "/usr/local/lib/python3.9/dist-packages/pyzm/api.py", line 80, in __init__ self._login() File "/usr/local/lib/python3.9/dist-packages/pyzm/api.py", line 205, in _login rj = r.json() File "/usr/lib/python3/dist-packages/requests/models.py", line 900, in json return complexjson.loads(self.text, **kwargs) File "/usr/lib/python3/dist-packages/simplejson/__init__.py", line 525, in loads return _default_decoder.decode(s) File "/usr/lib/python3/dist-packages/simplejson/decoder.py", line 370, in decode obj, end = self.raw_decode(s) File "/usr/lib/python3/dist-packages/simplejson/decoder.py", line 400, in raw_decode return self.scan_once(s, idx=_w(s, idx).end())simplejson.errors.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
Zoneminder is v1.36.4
I can't work this one out - any help great appreciated
Nick.
Nick.
