All,
I have ZM v.1.34.21 installed as a plug in on TrueNAS 12.0. I'm using Reolink cameras. One is an RLC-410-5MP the other is an E1. Neither have been capturing. I removed the E1 to focus on the 410 to start. Checking the logs I noticed a few errors. One was a time zone issue that isn't making sense as TrueNAS, ZM, and the cameras are all set to the same time zone. The other error indicates inability to find the protocol for the rtmp stream. The log file is included.
Failure to capture
Re: Failure to capture
You didn't give the source path you're using...but maybe this will help:
viewtopic.php?t=25874&start=15
