Page 1 of 1
Monitor won't snap to grid
Posted: Wed May 19, 2021 6:24 pm
by virtualbitz
I've been having a bizarre issue with ZMNinja for Windows. I have one monitor MICCAM05 that won't snap to grid. They also keep getting disabled every time I navigate away from the Montage view. If I enable them, I can view the monitor without issue. I can expand the monitor, but when I close the expanded view to go back to Montage, the monitor is disabled again. Logs are attached.
Re: Monitor won't snap to grid
Posted: Wed May 19, 2021 7:04 pm
by virtualbitz
Update: This only affects ZMNinja for Windows, My Android instance works as expected, no issues with MICCAM05 being disabled constantly.
I switch between about 5 Windows computers regularly, all running ZMNinja, all experience the same issue with MICCAM05
Posted: Sat May 22, 2021 12:57 am
by asker
Was this monitor added after you configured your windows client? If so running wizard again will fix it. It’s a bug in 1.6.008. If not it’s something else.
Posted: Fri Jun 18, 2021 12:32 am
by virtualbitz
That fixed it. Thanks!
