Page 1 of 1
strange datarate on record
Posted: Fri May 07, 2021 2:18 am
by jay23
i have 3 identical Cameras (Reolink RLC-520).
Same config.
Same config on ZM 1.32.3 (debian Buster).
The first is locked at 10fps, the second at 25 and the third at 8.
Where comes the difference in kB/s from?
Why does the first Cam produces twice as much at 10fps, as the 2nd on 12fps?
Tia
Jay
Re: strange datarate on record
Posted: Fri May 07, 2021 7:48 am
by Magic919
How does this compare with the camera output? What are the actual rates?
Posted: Fri May 07, 2021 7:17 pm
by jay23
Where should i look for it?
In the records?
There is the rate stated by the picture.
Posted: Sat May 08, 2021 6:08 am
by Magic919
Measure it. Make a 10 minute recording from each camera, check file size, calculate bit rate.
Posted: Sun May 09, 2021 8:18 am
by jay23
Ah, ok. You mean bitrates, not framerates. :-)
I have set a variable bitrate with maximum 8k at all cams.
Is ZM able to influence the bitrates?
Posted: Sun May 09, 2021 8:51 am
by Magic919
You asked about bit rates.
And, no.
Posted: Sun May 09, 2021 12:49 pm
by Acewiza
Sooooo, the "question" is: how are frame rate and bitrate related to Zoneminder's ability to manage those variables? :wink:
If anybody thinks calculating file sizes and jumping through math hoops is a way to operate a computer system in 2021, they have another thing coming...
Posted: Mon May 10, 2021 1:55 am
by jay23
You are right.
The bitrate ist between 7 and 10k on 1
and between 2 and 5k on 2 and 3.
But - why? They are all configed to 8k Max.
What ist the improvement between 5 and 10k bitrate?
Tia
jay
Posted: Mon May 10, 2021 12:21 pm
by Magic919
I don't think I understand the question.
Posted: Tue May 11, 2021 12:57 am
by dougmccrary
If you switch the settings to another one of the three cameras, is the result similar?
Also, are the cams seeing similar scenes in terms of motion?
Posted: Tue May 11, 2021 4:49 am
by jay23
Magic919 wrote: Mon May 10, 2021 12:21 pm I don't think I understand the question.
Is there a better picture with 10mbit?
The fps and resolution is the same.
Posted: Tue May 11, 2021 4:50 am
by jay23
dougmccrary wrote: Tue May 11, 2021 12:57 am If you switch the settings to another one of the three cameras, is the result similar?
Cam 1 and Cam 2 sees the same Scene from different Directions.
Posted: Tue May 11, 2021 5:59 am
by dougmccrary
OK. So if you reverse the setting of cam1 and 2, does FPS and datarate follow the same pattern? I'm wondering if they are really identical.
