Eventnotification Issue (timeout)
I had my hard drive crash and reinstalled everything to a new drive using ubuntu 20.04 and zoneminder 1.34.25 I have everything working with a letsencript certificate I can view monitors and events on zmninga. but I seem to have an issue with detection hooks, things pause at the username/password the after a minute or so the error follows. I followed installation and step by step but I am stuck here.
==> /var/log/zm/zmesdetect_m1.log <==
04/18/21 12:41:29 zmesdetect_m1[5417] DBG2 utils.py:383 [Secret token found in config: !ZM_PASSWORD]
04/18/21 12:41:29 zmesdetect_m1[5417] DBG2 utils.py:383 [Secret token found in config: !ZM_API_PORTAL]
04/18/21 12:41:29 zmesdetect_m1[5417] DBG2 utils.py:383 [Secret token found in config: !PLATEREC_ALPR_KEY]
04/18/21 12:41:29 zmesdetect_m1[5417] DBG1 utils.py:445 [allowing self-signed certs to work...]
04/18/21 12:41:29 zmesdetect_m1[5417] DBG4 utils.py:455 [Now checking for monitor overrides]
04/18/21 12:41:29 zmesdetect_m1[5417] DBG4 utils.py:523 [Finally, doing parameter substitution]
04/18/21 12:41:29 zmesdetect_m1[5417] INF zm_detect.py:296 [Importing local classes for Object/Face]
04/18/21 12:41:29 zmesdetect_m1[5417] INF zm_detect.py:321 [Connecting with ZM APIs]
04/18/21 12:41:29 zmesdetect_m1[5417] DBG2 api.py:67 [API SSL certificate check has been disbled]
04/18/21 12:41:29 zmesdetect_m1[5417] DBG1 api.py:176 [using username/password for login]
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 581, in post
return self.request('POST', url, data=data, json=json, **kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='myserver.com', port=443): Max retries exceeded with url: /zm/api/host/login.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f943b8c9ac0>: Failed to establish a new connection: [Errno 110] Connection timed out'))
Re: Eventnotification Issue (timeout)
The detection scripts can't access ZM
Check your secrets.ini and make sure the server names are correct (and unless you changed the hostname to myserver.com for the post, it is unlikely that is your real ZM server)
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
sorry it did take the actual server name out
Update, I disabled hooks and now my zmninja notifications come to my phone. It seems with hooks on, I can't get past the username/password line. I assume that is a zoneminder username and password that I have in my secrets.ini.
The DBG2 line saying "API SSL certificate check has been disbled" is coming from where? I don't have self signed certificates and I have SSl turned on in the configuration file as well as on zmninja
No idea. Post full debug logs of zm_detect from the start. You may want to read the documentation on how to manually run zm_detect with --debug
ES docs
zmNinja docs
ES docs
zmNinja docs
This is the complete log when a detection takes place. Any help pointing me in the right direction would be appreciated
04/20/21 09:01:03 zmesdetect_m1[10116] DBG2 utils.py:383 [Secret token found in config: !ZM_USER]
04/20/21 09:01:03 zmesdetect_m1[10116] DBG2 utils.py:383 [Secret token found in config: !ZM_PASSWORD]
04/20/21 09:01:03 zmesdetect_m1[10116] DBG2 utils.py:383 [Secret token found in config: !ZM_API_PORTAL]
04/20/21 09:01:03 zmesdetect_m1[10116] DBG2 utils.py:383 [Secret token found in config: !PLATEREC_ALPR_KEY]
04/20/21 09:01:03 zmesdetect_m1[10116] DBG1 utils.py:447 [strict SSL cert checking is on...]
04/20/21 09:01:03 zmesdetect_m1[10116] DBG4 utils.py:455 [Now checking for monitor overrides]
04/20/21 09:01:03 zmesdetect_m1[10116] DBG4 utils.py:523 [Finally, doing parameter substitution]
04/20/21 09:01:03 zmesdetect_m1[10116] INF zm_detect.py:296 [Importing local classes for Object/Face]
04/20/21 09:01:04 zmesdetect_m1[10116] INF zm_detect.py:321 [Connecting with ZM APIs]
04/20/21 09:01:04 zmesdetect_m1[10116] DBG1 api.py:176 [using username/password for login]
04/20/21 09:03:14 zmesdetect_m1[10116] FAT zm_detect.py:554 [Unrecoverable error:HTTPSConnectionPool(host='centinelview.chickenkiller.com', port=443): Max retries exceeded with url: /zm/api/host/login.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f1470498b20>: Failed to establish a new connection: [Errno 110] Connection timed out')) Traceback:Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 159, in _new_conn
conn = connection.create_connection(
File "/usr/lib/python3/dist-packages/urllib3/util/connection.py", line 84, in create_connection
raise err
File "/usr/lib/python3/dist-packages/urllib3/util/connection.py", line 74, in create_connection
sock.connect(sa)
TimeoutError: [Errno 110] Connection timed out
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 665, in urlopen
httplib_response = self._make_request(
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 376, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 996, in _validate_conn
conn.connect()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 314, in connect
conn = self._new_conn()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 171, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7f1470498b20>: Failed to establish a new connection: [Errno 110] Connection timed out
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 719, in urlopen
retries = retries.increment(
File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 436, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='my.real.servername.com, port=443): Max retries exceeded with url: /zm/api/host/login.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f1470498b20>: Failed to establish a new connection: [Errno 110] Connection timed out'))
File "/var/lib/zmeventnotification/bin/zm_detect.py", line 549, in <module>
main_handler()
File "/var/lib/zmeventnotification/bin/zm_detect.py", line 322, in main_handler
zmapi = zmapi.ZMApi(options=api_options)
File "/usr/local/lib/python3.8/dist-packages/pyzm/api.py", line 75, in __init__
self._login()
File "/usr/local/lib/python3.8/dist-packages/pyzm/api.py", line 188, in _login
r = self.session.post(url, data=data)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='my.real.servername.com', port=443): Max retries exceeded with url: /zm/api/host/login.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f1470498b20>: Failed to establish a new connection: [Errno 110] Connection timed out'))
raise err
sock.connect(sa)
conn.connect()
main_handler()
self._login()
The API responds when I test it (albeit not authenticated). Don't know why Python requests is having trouble with it. Have you tested this from the machine that runs ZMES? I'm wondering about DNS, for example.
The logs were from the machine that was running zmes.
Bottom line, zm_detect cannot reach your ZM server. Things to look at:
a) Check the value of ZM_PORTAL in /etc/zm/secrets.ini and make sure it is accurate
b) Make sure the portal keyword in objectconfig.ini points to !ZM_PORTAL
c) Make sure you are indeed using HTTPS as your logs show
d) From a terminal try to do a "telnet <the servername you see in the logs> 443". Are you able to connect? That is where zm_detect is trying to connect to.
If you still don't know what is going on:
a) Modify ZM_PORTAL value in /etc/zm/secrets.ini to "BADNAME.BAD" or something like that and see if its being picked up in logs. Then at least you know the files you think have the right values are the files that are being picked up.
ES docs
zmNinja docs
ES docs
zmNinja docs
Thanks. Still having issues but I changed the portal to my localhost and I got past this step but stopped again returning the image using the servername. I must have something configured wrong in apache or a file permission issue because I also noticed I can't reach my server using the domain name as I could before my new hard drive was installed. Can't even display the apache default page unless I use the local server address.
I'd encourage you to read the documents properly...
This is covered in both key principles and the FAQ
Your images are controlled by the value in picture_url in zmeventnotification.ini which usually uses a value specified in secrets.ini (ZMES_PICTURE_URL)
However, doing localhost for the picture won't work anyway. You'll need to resolve your domain/DNS/firewall issues.
ES docs
zmNinja docs
ES docs
zmNinja docs
As I said before, I can reach the API from here, which says it's working. I could also see the default Apache page.
The fact the dynamic DNS hostname I used is in the logs, says that bit works too.
@Magic919 not sure who you are responding to. This post is in response to the OP who started the thread.
ES docs
zmNinja docs
ES docs
zmNinja docs
Mostly the OP, and as an FYI for you, so you can see what works.
